[postgis-users] BOX3D functions
Mikael Carneholm
Mikael.Carneholm at WirelessCar.com
Sun Nov 20 02:29:55 PST 2005
I have problems creating a function that creates a bounding box given the coordinates for a point. It seems to be the same problem as in
http://postgis.refractions.net/pipermail/postgis-users/2005-November/009837.html.
Here's the first version:
create or replace function createbb(latitude numeric, longitude numeric, size_m integer) returns box3d as $$
declare
lat_multiplier numeric := 0.0000110574;
long_multiplier numeric := 0.0000111319;
begin
return 'BOX3D('||
(latitude+size_m*lat_multiplier)||' '||(longitude+size_m*long_multiplier)||', '||
(latitude-size_m*lat_multiplier)||' '||(longitude-size_m*long_multiplier)||')'::box3d;
end;
language plpgsql;
=> select createbb(53.948821,10.858131,1000);
ERROR: BOX3D parser - doesnt start with BOX3D(
CONTEXT: SQL statement "SELECT 'BOX3D('|| ( $1 + $2 * $3 )||' '||( $4 + $5 * $6 )||', '|| ( $7 - $8 * $9 )||' '||( $10 - $11 * $12 )|| ')'::box3d"
PL/pgSQL function "createbb" line 5 at return
Using the suggested expand(geometry,float)::box3d solution to return a box3d works in that it does create a box3d:
create or replace function createbb2(latitude numeric, longitude numeric, size_m integer) returns box3d as $$
declare
latlong_multiplier numeric := 0.0000111319;
begin
return expand( makepoint(latitude,longitude), (size_m*latlong_multiplier) )::box3d;
end;
language plpgsql;
=> select createbb2(53.948821,10.858131,1000);
BOX3D(53.937686920166 10.8469982147217 0,53.9599533081055 10.8692636489868 0)
However, this box3d does not work as expected:
=> explain select
p.point__id,
p.latitude,
p.longitude
from point p
where
p.geo && SetSRID(createbb2(53.948821,10.858131,100), 3007);
QUERY PLAN
Seq Scan on point p (cost=0.00..81962.20 rows=6 width=37)
Filter: (geo && setsrid((createbb2(53.948821, 10.858131, 100))::geometry, 3007))
(2 rows)
Reference plan when not using createbb2 ("manual" box3d creation):
=> explain select
p.point__id,
p.latitude,
p.longitude
from point p
where
p.geo && SetSRID('BOX3D(47.2 -1.68, 46.0 -1.67)'::box3d, 3007);
QUERY PLAN
Index Scan using idx_point_geo on point p (cost=0.00..114.35 rows=28 width=37)
Index Cond: (geo && '0103000020BF0B000001000000050000000000000000004740E17A14AE47E1FABF0000000000004740B81E85EB51B8FABF000000A099994740B81E85EB51B8FABF000000A099994740E17A14AE47E1FABF0000000000004740E17A14AE47E1FABF'::geometry)
(2 rows)
Strange, huh?
I would still prefer to be able to use the first version ("createbb") as expand doesn't let you scale the x,y dimensions differently. But for now I just want to make use of the index, any ideas why this is not happening?
Btw:
select version();
version
PostgreSQL 8.0.3 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.4.3 20050227 (Red Hat 3.4.3-22.fc3)
(1 row)
select postgis_version();
postgis_version
1.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
(1 row)
/Mikael
