[postgis-users] Query crashed
Paul Ramsey
pramsey at refractions.net
Sun Nov 20 12:40:44 PST 2005
Oh, one other thing, unless there is something wrong, things which
are "almost the same" should have bounding boxes that interact with a
tolerance level of 0. So you should be able to do the query without
the expand() at all, and still get the same results. Not that this
is the fix for the bug, but it should at least be fast and
effective :) (I think the only features for which this would fail
would be shorter than your tolerance number.)
select count(*)
from
roadseg r, streets s
where
r.the_geom && s.the_geom and
max_distance(s.the_geom, r.the_geom) < 0.00007;
Paul
On 19-Nov-05, at 9:39 PM, Paul Ramsey wrote:
> We'll wait until Mark gets back on the list and comments, probably
> a problem with the function(geometry) && geometry construction and
> the index selectivity calculation. Mark was working on spatial
> join selectivity a couple months ago, but this might be a case he
> did not anticipate.
> P
> On 19-Nov-05, at 4:38 PM, Stephen Woodbridge wrote:
>> Paul,
>> Thank you for the help and suggestions. max_distance() sounds like
>> a good way around the crash problem, but I get ...
>> canada=# select count(*)
>> canada-# from
>> canada-# roadseg r, streets s
>> canada-# where
>> canada-# expand(r.the_geom, 0.00007) && s.the_geom and
>> canada-# max_distance(s.the_geom, r.the_geom) < 0.00007;
>> NOTICE: LWGEOM_gist_joinsel called with arguments that are not
>> column references
>> ERROR: This function is unimplemented yet
>> I have the function defined in my database as:
>> CREATE OR REPLACE FUNCTION max_distance(geometry, geometry)
>> RETURNS float8 AS
>> '/usr/local/lib/liblwgeom.so.1', 'LWGEOM_maxdistance2d_linestring'
>> LANGUAGE 'c' IMMUTABLE STRICT;
>> ALTER FUNCTION max_distance(geometry, geometry) OWNER TO pgsql;
>> -Steve
>> Paul Ramsey wrote:
>>> Just realized, there is a max_distance() function in PostGIS, so
>>> you can make replace the within(buffer()) call with something
>>> much faster that is almost semantically equivalent:
>>> select count(*)
>>> from
>>> where
>>> The semantics of max_distance are here:
>>> <http://postgis.refractions.net/pipermail/postgis-users/2002-
>>> January/ 000554.html>
>>> P.
>>> On 19-Nov-05, at 2:29 PM, Paul Ramsey wrote:
>>>> Well, you crashed the backend... probably with the buffer(),
>>>> though the gist_joinsel error is oddball. Oh, your GEOS is
>>>> quite over a year old and a lot of bugs have been scrubbed
>>>> since then, so an upgrade there would help in general.
>>>> Finally, your query syntax is hell, here is why:
>>>> buffer(foo) && somethingelse
>>>> you are doing an incredibly expensive geometry operation
>>>> (buffer ()) and then only comparing the bounding box! use expand
>>>> () instead
>>>> within(something,buffer(foo))
>>>> well, I see what you are doing here, and there is currently
>>>> no other way. you are looking for items which are "mostly
>>>> equal" to other items. that is, they may have had some
>>>> coordinate drift do to rounding errors, or been noded in
>>>> places, or had some vertices added or removed, but they
>>>> basically describe the same line on the ground. what is really
>>>> needed is a kindaequals (geom_a,geom_b,tolerance) function that
>>>> returns a number of values, depending on the equality case: 1 =
>>>> completely equal, 2 = describe the same line within tolerance,
>>>> 3 = geom_a is same as geom_b but shorter, 4 = geom_b is same as
>>>> geom_a but shorter.
>>>> P.
>>>> On 19-Nov-05, at 1:56 PM, Stephen Woodbridge wrote:
>>>>> Hi all,
>>>>> I was running the following query:
>>>>> select count(*)
>>>>> from
>>>>> where
>>>>> buffer(r.the_geom, 0.00007) && s.the_geom and
>>>>> within(s.the_geom, buffer(r.the_geom, 0.00007));
>>>>> And it crashed with the following error message after running
>>>>> for 1,959,844 ms in pgadmin3:
>>>>> not column references
>>>>> server closed the connection unexpectedly
>>>>> This probably means the server terminated abnormally
>>>>> before or while processing the request.
>>>>> The "roadseg" table is the geobase roadseg data for all
>>>>> provinces loaded into a table and the "streets" is the same
>>>>> for the Census streets data for all provinces.
>>>>> postgis_full_version() reports:
>>>>> POSTGIS="1.0.4"
>>>>> GEOS="2.0.1"
>>>>> PROJ="Rel. 4.4.9, 29 Oct 2004"
>>>>> USE_STATS DBPROC="0.3.0"
>>>>> RELPROC="0.3.0"
>>>>> and version() reports:
>>>>> "PostgreSQL 8.0.4 on i386-portbld-freebsd5.3, compiled by GCC
>>>>> cc (GCC) 3.4.2 [FreeBSD] 20040728"
>>>>> Any ideas on what this is about. All the data was loaded via
>>>>> shp2pgsql.
>>>>> Thanks,
>>>>> -Steve
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
