[postgis-users] Generating POINT geometry column for PostGIS from split latitude/longitude component fields.
Nicolas Ribot
nicky666 at gmail.com
Fri Nov 25 01:19:46 PST 2005
What about adding a true geometric column to your table with the
make_point() function ?
Maybe a trigger could do it automatically each time you insert a new
value in your table.
According to the north/south attribute, you will have to sign the
numerical values for lat/long.
(BTW, the textual representation for a point (WKT) only expects
numerical values for coordinates, so DMS values should be converted
into decimal degrees)
On 11/25/05, Carlo Tronnberg <temp at chello.hu> wrote:
> Dear list,
> I have a PostgreSQL table as follows:
> CREATE TABLE lineup
> lineup_id int4 NOT NULL DEFAULT
> nextval('lineup_lineup_id_seq'::regclass),
> state char(1) NOT NULL DEFAULT 'T'::bpchar,
> gps_lat_degree int4,
> gps_long_degree int4,
> gps_altitude int4,
> gps_lat_hemisphere char(1),
> gps_long_hemisphere char(1),
> gps_lat_minutes float8,
> gps_long_minutes float8,
> CONSTRAINT lineup_gps_lat_hemisphere_check CHECK (gps_lat_hemisphere =
> 'S'::bpchar OR gps_lat_hemisphere = 'N'::bpchar),
> CONSTRAINT lineup_gps_long_hemisphere_check CHECK
> (gps_long_hemisphere = 'E'::bpchar OR gps_long_hemisphere = 'W'::bpchar),
> CONSTRAINT lineup_gps_magn_hemisphere_check CHECK
> (gps_magn_hemisphere = 'E'::bpchar OR gps_magn_hemisphere = 'W'::bpchar),
> CONSTRAINT lineup_state_check CHECK (state = 'T'::bpchar OR state =
> 'O'::bpchar OR state = 'F'::bpchar OR state = 'S'::bpchar)
> WITH OIDS;
> ALTER TABLE lineup OWNER TO postgres;
> I want to extract the lat/lon coordinates via PostGIS for plotting a point
> (or symbol) for each record, the color of which is determined by the value
> of the state field. My problem is the the longitude and latitude are split
> into their components( latitude degrees + latitude minutes + latitude
> hemisphere...) given from a GPS system.
> How can I generate the POINT geometry column in order to contain the POINT
> object?
> I experimented with Views but I doubt this is the way to go
> I could display the POINT construction such as
> CREATE OR REPLACE VIEW stations_pos AS:
> SELECT ((((((((('POINT('::text || lineup.gps_long_degree::text) ||
> ':'::text) || lineup.gps_long_minutes::text) ||
> lineup.gps_long_hemisphere::text) || ' '::text) ||
> lineup.gps_lat_degree::text) || ':'::text) || lineup.gps_lat_minutes::text)
> || lineup.gps_lat_hemisphere::text) || ')'::text AS "position"
> FROM lineup;
> which gives query answers such as: POINT(18:44.2333W 42:31.3667S)
> I tried to convert this string based definition to POINT object but it did
> not work (I am not sure if this representation is ok in PostGIS):
> SELECT GeomFromText(((((((((('POINT('::text ||
> lineup.gps_long_degree::text || ':'::text) || lineup.gps_long_minutes::text)
> || lineup.gps_long_hemisphere::text) || ''::text) ||
> || lineup.gps_lat_hemisphere::text || ')'::text), 4326)) AS "position" FROM
> lineup;
> I doubt this is the way to go. This might give a big overhead and slow down
> the database.
> Any ideas?
> Thanks for your help!
> Cheers,
> Carlo
> postgis-users mailing list
