[postgis-users] SQL query to identify tables and views with geometry field
Armin Burger
armin.burger at gmx.net
Fri Nov 25 11:43:53 PST 2005
But this query does not find the views based on tables, even if the
tables themselves are registered in geometry_columns. Programs like QGIS
and uDig seem to be able to find all tables and views with geometry
columns, so I guess there seems to be a SQL query based on PG system
tables for this.
Armin
Sean Gillies wrote:
> On Nov 25, 2005, at 12:28 PM, Armin Burger wrote:
>> Hi everyone,
>> is there a way to find all tables and views in a PostGIS-enabled
>> database that contain a geometry field, using just a SQL query?
>> Armin
> If your database is in proper shape
> select f_table_name from geometry_columns;
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://zcologia.com/news
> postgis-users mailing list
