[postgis-users] Adding postgis column in COPY command?
Rick Schumeyer
rschumeyer at ieee.org
Mon Nov 28 08:47:54 PST 2005
I have a database which does not yet contain a geometry column. I populate
the database by creating a text file containing the records
from a perl script, and then issuing a COPY command.
I plan on adding a geometry column, but I am not sure the best way to get
the geometry information in. I have seen examples
like "INSERT . GeomFromText(.)". I'm guessing that I can't simply put a
GeomFromText(.) in a text file that is read
by the COPY command.
I could change the COPY to multiple INSERTS, but I believe this would really
slow things down. I'm not familiar enough with postgis
to know if there is a way to do this with COPY.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051128/feec7b99/attachment.html>
