[postgis-users] Error using AddGeometryColumn
strk at refractions.net
Wed Nov 30 07:43:56 PST 2005
Try make clean and re-make under postgis-1.0.4, and
check that USE_VERSION is set to 81.
It looks like the lwpostgis.sql you're using has
been produced for a previous version of postgresql.
--strk;
On Wed, Nov 30, 2005 at 09:54:43AM -0500, Rick Schumeyer wrote:
> I'm using postgis 1.0.4 with postgresql 8.1.0. I have previously created
> and loaded a postgis database in this system, and everything seems to work.
> In an attempt to test something, I created a different database and tried to
> create the same tables, but this time I get an error, shown at the end.
> (I have previously created a table "data").
> I have no clue what this error means.
> #create language plpgsql;
> #\i /home/rick/ftp/postgresql-8.1.0/contrib/postgis-1.0.4/lwpostgis.sql
> #\i
> /home/rick/ftp/postgresql-8.1.0/contrib/postgis-1.0.4/spatial_ref_sys.sql
> # select AddGeometryColumn('data','geom',2959,'POINT',2);
> ERROR: row "mislinked" has no field "attrelid"
> CONTEXT: compile of PL/pgSQL function "fix_geometry_columns" near line 80
> SQL statement "SELECT fix_geometry_columns()"
> PL/pgSQL function "addgeometrycolumn" line 154 at select into variables
> SQL statement "SELECT AddGeometryColumn('','', $1 , $2 , $3 , $4 , $5 )"
> PL/pgSQL function "addgeometrycolumn" line 4 at select into variables
> postgis-users mailing list
/"\ ASCII Ribbon Campaign
\ / Respect for open standards
X No HTML/RTF in email
/ \ No M$ Word docs in email
