[postgis-users] Making shp2pgsql using iconv in /usr/local?
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Wed Nov 30 19:01:39 PST 2005
Hello again,
On second thought, a cleaner solution to this is to add "#define
LIBICONV_PLUG" just before the line with "#include <iconv.h>" in
shp2pgsql.c. This essentially accomplishes the same (i.e., avoids
redefinition of the libiconv_* functions), and without hacking-up the
iconv.h like I did in my previous. I tried to do this via the make
command like so:
CFLAGS="-DLIBICONV_PLUG" make
as well as
CFLAGS="-DLIBICONV_PLUG" make loaderdumper
but that had no effect (is this right the right way?). I think part of
the issue here is that CFLAGS is reset at the start of loader/Makefile,
so any CFLAGS (or LDFLAGS) options that are supplied when executing make
are wiped by the time the loader source is compiled.
Should LIBICONV_PLUG be an option that is just always enabled when
USE_ICONV=1, or should it be optional? Everything worked fine when I
added "LIBICONV_PLUG = 1" in Makefile.config, then the following lines
in loader/Makefile:
ifeq ($(LIBICONV_PLUG),1)
override CFLAGS += -DLIBICONV_PLUG
endif
Anyway, that's all for now.
Regards,
Mike
Mike Leahy wrote:
> Hey there,
> I think this problem might be related to a bug found with MapServer a
> while back: http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=909
> I tried commenting out the following lines in /usr/local/include/iconv.h
> (version 1.10), and PostGIS compiled without errors:
> 45: //#undef iconv_t
> 46: //#define iconv_t libiconv_t
> 70: //#define iconv_open libiconv_open
> 80: //#define iconv libiconv
> 86: //#define iconv_close libiconv_close
> 96: //#define iconvctl libiconvctl
> 119: //#define iconvlist libiconvlist
> I have no idea if this breaks anything...I just figured it was related
> to conflicting libraries as suggested in the MapServer bug referenced
> above.
> I'm running FC4, with the most recent upgrades.
> I hope this helps.
> Mike
> Larry Shaffer wrote:
>> strk,
>> Sorry for the lack of info on my part. I'd like to get this working, but
>> it's no big thing until I get ready to install the upcoming PostGIS 1.0.6
>> version, as this is a brand new setup (PostgreSQL and all) with no real
>> data installed into yet.
>> Make for PostGIS works fine with USE_ICONV ?= 0
>> My src path is /usr/local/src/postgresql-8.1.0/contrib/postgis
>> These are the values in the PGISSRC/Makefile.config:
>> USE_PROJ ?= 1
>> PROJ_DIR ?= /usr/local
>> USE_GEOS ?= 1
>> GEOS_DIR ?= /usr/local
>> USE_JTS ?= 0
>> JTS_INCLUDES = /usr/local/include
>> JTS_LIBDIR = /usr/local/lib
>> USE_STATS=1
>> AUTOCACHE_BBOX ?= 1
>> PGSQL_SRC=/usr/local/src/postgresql-8.1.0
>> USE_ICONV ?= 1
>> (set to 0 for PostGIS make, then to 1 for shp2pgsql make)
>> LPATH=/usr/local/src/postgresql-8.1.0/contrib/postgis
>> What's in /usr/local/lib
>> libiconv_plug.so
>> libiconv.la
>> libiconv.so
>> libiconv.so.2
>> libiconv.so.2.2.0
>> What's in /usr/local/include
>> iconv.h
>> and whereis?
>> sh-2.05a# whereis libiconv
>> libiconv: /usr/local/lib/libiconv.so /usr/local/lib/libiconv.la
>> sh-2.05a# whereis iconv
>> iconv: /usr/bin/iconv /usr/local/bin/iconv /usr/include/iconv.h /usr/
>> share/man/man1/iconv.1.gz /usr/share/man/man3/iconv.3.gz
>> (Where is /usr/local/include/iconv.h? It *does* exist in /usr/local/
>> include. This could be the problem...)
>> Running iconv -l for /usr and /usr/local provides positive results of
>> listing encodings (i.e. both are working).
>> sh-2.05a# /usr/bin/iconv --version
>> iconv (GNU libc) 2.2.5
>> Copyright (C) 2002 Free Software Foundation, Inc.
>> Written by Ulrich Drepper.
>> sh-2.05a# /usr/local/bin/iconv --version
>> iconv (GNU libiconv 1.9)
>> Copyright (C) 2000-2002 Free Software Foundation, Inc.
>> Written by Bruno Haible.
>> I installed the libiconv-1.9.1 from GNU since it was a standalone.
>> Should I install the Standard C library (glibc-2.3.2) in /usr/local ? I
>> don't think the /usr/local extras before make command of shp2pgsql are
>> making a difference, so I don't think it's worth the effort right now.
>> See the following...
>> Here's the output from the /usr/local extras
>> (run from within contrib/postgis/loader)
>> sh-2.05a# LDFLAGS="-L/usr/local/lib -liconv" CFLAGS="-I/usr/local/
>> include" make shp2pgsql
>> make: `shp2pgsql' is up to date.
>> sh-2.05a# make clean
>> rm -f shpopen.o dbfopen.o getopt.o PQunescapeBytea.o shp2pgsql.o
>> pgsql2shp.o shp2pgsql pgsql2shp
>> gcc -g -Wall -I.. -I. -I/usr/local/src/postgresql-8.1.0/src/interfaces/
>> libpq -O2 -Wall -Wmissing-prototypes -Wpointer-arith -Winline -fno-
>> strict-aliasing -DUSE_ICONV -DFRONTEND -DSYSCONFDIR='"/usr/local/pgsql/
>> etc"' -DUSE_VERSION=81 -I/usr/local/src/postgresql-8.1.0/src/include -
>> D_GNU_SOURCE -I/usr/local -c -o shpopen.o shpopen.c
>> shpopen.c:176: warning: `rcsid' defined but not used
>> D_GNU_SOURCE -I/usr/local -c -o dbfopen.o dbfopen.c
>> dbfopen.c:200: warning: `rcsid' defined but not used
>> D_GNU_SOURCE -I/usr/local -c -o getopt.o getopt.c
>> D_GNU_SOURCE -I/usr/local -c -o PQunescapeBytea.o PQunescapeBytea.c
>> D_GNU_SOURCE -I/usr/local -c -o shp2pgsql.o shp2pgsql.c
>> etc"' -DUSE_VERSION=81 shpopen.o dbfopen.o getopt.o PQunescapeBytea.o
>> shp2pgsql.o -L/usr/local/src/postgresql-8.1.0/src/port -lstdc++ -L/usr/
>> local -Wl,-rpath,/usr/local/pgsql/lib -o shp2pgsql shp2pgsql.o: In
>> function `utf8':
>> /usr/local/src/postgresql-8.1.0/contrib/postgis/loader/shp2pgsql.c:1630:
>> undefined reference to `libiconv_open'
>> /usr/local/src/postgresql-8.1.0/contrib/postgis/loader/shp2pgsql.c:1648:
>> undefined reference to `libiconv'
>> /usr/local/src/postgresql-8.1.0/contrib/postgis/loader/shp2pgsql.c:1654:
>> undefined reference to `libiconv_close'
>> collect2: ld returned 1 exit status
>> make: *** [shp2pgsql] Error 1
>> and without the /usr/local extras... just 'make shp2pgsql'...
>> exactly the same results.
>> I don't think /usr/local/include/incov.h is being located. Either way,
>> it's failing to make when using the base install of Debian
>> [linus]$ uname -a
>> Linux linus 2.4.28-grsec+w+fhs6b+gr0501+nfs+++p4+c4+gr6b-v6.188 #1 SMP
>> Fri Jan 14 11:41:59 PST 2005 i686 unknown
>> Any help would be appreciated. Thanx.
> postgis-users mailing list
