[postgis-users] I need Install PostGis
strk at refractions.net strk at refractions.net
Mon Oct 3 00:59:51 PDT 2005
On Fri, Sep 30, 2005 at 03:27:19PM -0300, Jose A. Benitez wrote:
> Hi... PostGis USers
> I have a machine with DebianAMD64, I selected this operating system because
> I have an AMD ATHLON-64,
> I have ready Postgres 7.4.7, I installed from its package, but I need now to
> install PostGIS,
> I tell you step by step that things that I've done
>    1. I downloaded the postgre's sources from Debian's ftp, I downloaded
>    the src of PostGis 1.0.3
>    2. I have postgre's src on /usr/src/postgres
>    3. I have PostGi's src on /usr/src/postgres/contrib/postgis
>    4. I edited the MakeFile.config how say the manual called postgis.pdf
>    5. then I type Make on a Terminal as root
> Its messages is the following:
> debian64:/usr/src/postgresql/contrib/postgis# make
> make -C lwgeom
> make[1]: Entering directory `/usr/src/postgresql/contrib/postgis/lwgeom'
> /usr/src/postgresql/contrib/postgis/../../src/Makefile.global:278:
> /usr/src/postgresql/contrib/postgis/../../src/Makefile.port: No such file or
> directory
> make[1]: *** No rule to make target
> `/usr/src/postgresql/contrib/postgis/../../src/Makefile.port'. Stop.
> make[1]: Leaving directory `/usr/src/postgresql/contrib/postgis/lwgeom'
> make: *** [liblwgeom] Error 2
> The MakeFile.port don't exist in my PC...
> What thing I have done bad.....?
Can you find Makefile.port somewhere under /usr/src/postgres ?
Or anywhere else on your system ?
Did you run ./configure under your postgresql source tree ?
--strk;
> Thank..
> José Benitez
> I have instaled too Grass
> postgis-users mailing list
