[postgis-users] Overlap Queries - speed
Bill Binko
bill at binko.net
Mon Oct 3 14:53:22 PDT 2005
Fair enough: you can replace my intersects() with distance(a, b) <= 0
I can't keep track of all the tricks, I just realized that his && was not
going to be sufficient.
Bill
On Mon, 3 Oct 2005, Obe, Regina DND\MIS wrote:
> Yes I thought so too and I thought in general that the GEOS functions were a
> little slower than the non-geos ones or has that changed? Given that
> intersects is a GEOS function I would expect it to be slower. I haven't
> tested to verify those assumptions though.
> Another check? How much memory do you have allocated for worker_mem? It
> doesn't sound like you have all that much memory to work with, but boosting
> that may help a little since you are working with fairly large geometries.
> -----Original Message-----
> From: Ethan Alpert [mailto:ealpert at digitalglobe.com]
> Sent: Monday, October 03, 2005 5:12 PM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] Overlap Queries - speed
> Bill I thought it was discovered that distance() was faster than
> intersects()
> -e
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bill
> Binko
> Sent: Monday, October 03, 2005 2:28 PM
> Subject: Re: [postgis-users] Overlap Queries - speed
> On Mon, 3 Oct 2005, Robert Burgholzer wrote:
> > I have a question regarding performance, running postGIS 1.0.4 on
> > postgreSQL 8.0.3. running on RedHat Enterprise ES, 1.113 GHz Inter
> > Pentium III, 376 Megs of RAM
> > I am performing an intersection calculation on two spatial tables, the
> > tables are as follows:
> > bmp_multiseg : 6579 records
> > p5lrsegs : 2364 records
> > QUERY:
> > select a.msid, b.lrseg, b.landseg, b.riverseg,
> > area2d(intersection(a.the_geom, b.the_geom))/area2d(b.the_geom)
> from
> > bmp_multiseg as a, p5lrsegs as b where a.the_geom && b.the_geom;
> > basically, there are several inputs in bmp_multiseg at a number of
> > overlapping resolutions that I am distributing amongst the second
> > table p5lrsegs, with an average of ~ 6 overlaps from bmp_multiseg to
> > p5lrsegs, making a total of ~ 15,000 records in the resulting query.
> > This query takes over an hour to complete with spatial indices on both
> > tables geometry field.
> > The geometries are not simple, they range in size from between 5-20K
> > per row, perhaps this is part of the problem?
> > Any insight would be appreciated. Even if you tell me that this is
> > reasonable and I have to just suck it up, or look for another tool to
> > do my calculations, those kinds of insights are good to know.
> Well, one thing that might help would be to add an intersects() to your
> where clause. If you shapes are very irregular, your && will cause many
> false positives causing too many empty intersection shapes to be created.
> (Someone correct me if I'm wrong).
> So you might try:
> QUERY:
> area2d(intersection(a.the_geom, b.the_geom))/area2d(b.the_geom) from
> bmp_multiseg as a, p5lrsegs as b where a.the_geom && b.the_geom AND
> intersects(a, b);
> Another thing (obviously) is to make sure that your indexes are being
> used. Run a EXPLAIN on that query and post the results.
> Bill
> postgis-users mailing list postgis-users at postgis.refractions.net
