[postgis-users] Overlap Queries - speed
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Tue Oct 4 05:13:08 PDT 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Robert Burgholzer
> Sent: 03 October 2005 21:19
> To: PostGIS Users Discussion
> Subject: [postgis-users] Overlap Queries - speed
> I have a question regarding performance, running postGIS
> 1.0.4 on postgreSQL 8.0.3. running on RedHat Enterprise ES,
> 1.113 GHz Inter Pentium III, 376 Megs of RAM
> I am performing an intersection calculation on two spatial
> tables, the tables are as follows:
> bmp_multiseg : 6579 records
> p5lrsegs : 2364 records
> QUERY:
> select a.msid, b.lrseg, b.landseg, b.riverseg,
> area2d(intersection(a.the_geom,
> b.the_geom))/area2d(b.the_geom) from
> bmp_multiseg as a, p5lrsegs as b where a.the_geom && b.the_geom;
> basically, there are several inputs in bmp_multiseg at a
> number of overlapping resolutions that I am distributing
> amongst the second table p5lrsegs, with an average of ~ 6
> overlaps from bmp_multiseg to p5lrsegs, making a total of ~
> 15,000 records in the resulting query. This query takes over
> an hour to complete with spatial indices on both tables
> geometry field.
> The geometries are not simple, they range in size from
> between 5-20K per row, perhaps this is part of the problem?
> Any insight would be appreciated. Even if you tell me that
> this is reasonable and I have to just suck it up, or look for
> another tool to do my calculations, those kinds of insights
> are good to know.
> Thanks,
> r.b.
Hi Robert,
As per Amilcar's suggestion, if you would like to try explicitly adding
bounding boxes to your geometries in order to see if that makes a
difference, you should do:
UPDATE bmp_multiseg SET the_geom = addBBOX(the_geom);
UPDATE p5lrsegs SET the_geom = addBBOX(the_geom);
VACUUM FULL bmp_multiseg;
VACUUM FULL p5lrsegs;
VACUUM ANALYZE;
Then try your query again and see how long it takes in comparison.
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
