[postgis-users] Query performance issue
Bill Binko
bill at binko.net
Thu Oct 13 15:12:58 PDT 2005
Ok, just to throw my hat into the ring, why don't you try separating the
SELECT and the UPDATE.
--First, CLUSTER your streets table around its GIST index:
-- (This can take a while, but not hours)
CLUSTER streets_gidx on streets;
-- Second, grab the (possibly many-many) relationships
SELECT streets.oid as soid, prov_ab INTO TEMPORARY street_prov FROM
streets JOIN province ON (streets.the_grom && province.the_geom AND
distance(streets.the_geom, province.the_geom) <= 0;
-- Then, index them with both fields in the index...for fast lookup
CREATE INDEX street_prov_idx ON street_prov(soid, prov_ab);
-- I am only taking the first one.
UPDATE streets set prov = (select prov_ab from street_prov_idx where soid
= streets.oid limit 1);
If nothing else, you'd know which part of this is causing your pain.
Bill
PS: the CLUSTER is a good idea anyway
On Thu, 13 Oct 2005, Stephen Woodbridge wrote:
> So here are the variations on the UPDATE query and the respective query
> plans. Given that Plan 1: ran for over 16 hrs and the estimated runtime
> based on number of rows that had been updated is 261 hrs, does anyone
> have any suggestion as to which might be the next best to try?
> -Steve
> ### Plan 1: ran for 16 hrs and estimate runtime is 261 hrs
> explain update streets set prov=prov_ab from province b where
> streets.the_geom && b.the_geom and distance(streets.the_geom,
> b.the_geom) = 0.0
> Nested Loop (cost=0.00..581.99 rows=17990 width=307)
> Join Filter: (distance("inner".the_geom, "outer".the_geom) =
> 0::double precision)
> -> Seq Scan on province b (cost=0.00..1.14 rows=14 width=92196)
> -> Index Scan using streets_gidx on streets (cost=0.00..38.12
> rows=9 width=301)
> Index Cond: (streets.the_geom && "outer".the_geom)
> ### Plan 2:
> explain UPDATE streets SET prov = (
> SELECT prov_ab
> FROM province b
> WHERE streets.the_geom && b.the_geom AND intersects(streets.the_geom,
> b.the_geom)
> ORDER BY prov_ab
> LIMIT 1
> Seq Scan on streets (cost=0.00..2296390.04 rows=1798897 width=301)
> SubPlan
> -> Limit (cost=1.22..1.22 rows=1 width=6)
> -> Sort (cost=1.22..1.22 rows=1 width=6)
> Sort Key: prov_ab
> -> Seq Scan on province b (cost=0.00..1.21 rows=1
> width=6)
> Filter: (($0 && the_geom) AND intersects($0,
> the_geom))
> ### Plan 3:
> SELECT prov_ab
> FROM streets JOIN province b
> ON streets.the_geom && b.the_geom WHERE intersects(streets.the_geom,
> b.the_geom)
> ORDER BY prov_ab
> LIMIT 1
> Seq Scan on streets (cost=171335.34..264076.56 rows=1798897 width=301)
> InitPlan
> -> Limit (cost=171335.34..171335.34 rows=1 width=6)
> -> Sort (cost=171335.34..174333.52 rows=1199270 width=6)
> Sort Key: b.prov_ab
> -> Nested Loop (cost=0.00..536.70 rows=1199270 width=6)
> Join Filter: intersects("inner".the_geom,
> "outer".the_geom)
> (cost=0.00..38.12 rows=9 width=160)
> "outer".the_geom)
> ### Plan 4:
> ( select count(*) from streets, province
> where streets.the_geom && province.the_geom )=1
> or
> ( streets.the_geom && b.the_geom
> and distance(streets.the_geom, b.the_geom) = 0.0 );
> Nested Loop (cost=9530.91..1748998.34 rows=143822 width=307)
> Join Filter: (($0 = 1) OR (("inner".the_geom && "outer".the_geom) AND
> (distance("inner".the_geom, "outer".the_geom) = 0::double precision)))
> InitPlan
> -> Aggregate (cost=9530.91..9530.91 rows=1 width=0)
> -> Nested Loop (cost=0.00..536.38 rows=3597808 width=0)
> -> Seq Scan on province (cost=0.00..1.14 rows=14
> width=92190)
> -> Seq Scan on streets (cost=0.00..88243.97 rows=1798897 width=301)
> postgis-users mailing list
