[postgis-users] Problem with mapserver-postgis
Armin Burger
armin.burger at gmx.net
Sun Oct 16 03:57:56 PDT 2005
Is postmaster started with the -i option (enable TCP/IP connections)?
Armin
Juan Barón wrote:
> Hi:
> I have changed the connection string writing the password:
> CONNECTION "user=postgres password=postgres dbname=pruebapostgis
> host=localhost port=5432"
> and I obtain the same result:
> msDrawMap(): Image handling error. Failed to draw layer named 'callejero'.
> msPOSTGISLayerOpen(): Query error. couldnt make connection to DB with
> connect string 'user=postgres password=postgres dbname=pruebapostgis
> host=localhost port=5432'.
> Error reported was 'could not translate host name "localhost" to
> address: Unknown host '.
> This error occured when trying to make a connection to the specified
> postgresql server.
> Most commonly this is caused by
> (1) incorrect connection string
> (2) you didnt specify a 'user=...' in your connection string
> (3) the postmaster (postgresql server) isnt running
> (4) you are not allowing TCP/IP connection to the postmaster
> (5) your postmaster is not running on the correct port - if its not on
> 5432 you must specify a 'port=...'
> (6) the security on your system does not allow the webserver (usually
> user 'nobody') to make socket connections to the postmaster
> (7) you forgot to specify a 'host=...' if the postmaster is on a
> different machine
> (8) you made a typo
> I have also proven to connect me to the db from the command prompt with
> the login information and I connect myself well:
> psql pruebapostgis -U postgres
> somebody knows which is the problem, it seems that it doesn't transfer
> localhost to an address, I have also proven with 127.0.0.1 and neither
> it works
> From: /Prashanth Ram <pram123 at gmail.com>/
> Reply-To: /pram at pramcentral.com,PostGIS Users Discussion
> <postgis-users at postgis.refractions.net>/
> To: /PostGIS Users Discussion <postgis-users at postgis.refractions.net>/
> Subject: /Re: [postgis-users] Problem with mapserver-postgis/
> Date: /Sat, 15 Oct 2005 17:47:06 -0400/
> Juan:
> Have you tried connecting to the db from the command prompt with
> the login information?
> Also, the connection string is missing the password
> -Prashanth
> HTMLX.com
> Mapserver Hosting, Mapscript Hosting, PHP Hosting
> PostgreSQL w/PostGIS extension enabled Hosting
> On 10/15/05, *Juan Barón* <jbarong at hotmail.com
> <mailto:jbarong at hotmail.com>> wrote:
> Hello list,
> I am using mapserver 4.4.1 and postgresql 8.0 with postgis.
> I have a layer in the map file:
> LAYER
> CONNECTIONTYPE postgis
> NAME callejero
> CONNECTION "user=postgres dbname=pruebapostgis host=localhost
> port=5432"
> DATA "the_geom from tablacallejero"
> STATUS DEFAULT
> TYPE LINE
> CLASS
> COLOR 255 0 0
> END
> END
> and when I execute the application, the layer doesn't appear me
> and the
> result is a message for screen:
> 'callejero'.
> with
> connect string 'user=postgres dbname=pruebapostgis host=localhost
> port=5432'.
> address:
> Unknown host '.
> postgresql server.
> not on
> (usually
> different
> machine
> (8) you made a typo
> I have proven to change localhost for 127.0.0.1
> <http://127.0.0.1/>, but the result is the
> same one.
> postgresql this being executed, because if I put netstat - na
> appears:
> TCP 127.0.0.1:5432 <http://127.0.0.1:5432/> LISTENING
> I don't know which is the problem.
> Thank's
> postgis-users mailing list
> <mailto:postgis-users at postgis.refractions.net>
> HTMLX.com
> >_______________________________________________
