[postgis-users] Problem with mapserver-postgis
Paul Scott
pscott at uwc.ac.za
Sun Oct 16 12:12:51 PDT 2005
Also the default postgres user normally has no password.
--Paul
On Sun, 2005-10-16 at 18:55 +0000, Juan Barón wrote:
> I have pulled up postmaster with - i and it continues without working
> ______________________________________________________________
> From: Armin Burger <armin.burger at gmx.net>
> Reply-To: PostGIS Users Discussion
> <postgis-users at postgis.refractions.net>
> Subject: Re: [postgis-users] Problem with mapserver-postgis
> Date: Sun, 16 Oct 2005 12:57:56 +0200
> >Is postmaster started with the -i option (enable TCP/IP
> >connections)?
> >Armin
> >Juan Barón wrote:
> >>Hi:
> >>I have changed the connection string writing the password:
> >>CONNECTION "user=postgres password=postgres
> dbname=pruebapostgis
> >>host=localhost port=5432"
> >>and I obtain the same result:
> >>msDrawMap(): Image handling error. Failed to draw layer
> named
> >>'callejero'.
> >>msPOSTGISLayerOpen(): Query error. couldnt make connection
> to DB
> >>with connect string 'user=postgres password=postgres
> >>dbname=pruebapostgis host=localhost port=5432'.
> >>Error reported was 'could not translate host name
> "localhost" to
> >>address: Unknown host '.
> >>This error occured when trying to make a connection to the
> >>specified postgresql server.
> >>Most commonly this is caused by
> >>(1) incorrect connection string
> >>(2) you didnt specify a 'user=...' in your connection string
> >>(3) the postmaster (postgresql server) isnt running
> >>(4) you are not allowing TCP/IP connection to the postmaster
> >>(5) your postmaster is not running on the correct port - if
> its not
> >>on 5432 you must specify a 'port=...'
> >>(6) the security on your system does not allow the
> webserver
> >>(usually user 'nobody') to make socket connections to the
> >>postmaster
> >>(7) you forgot to specify a 'host=...' if the postmaster is
> on a
> >>different machine
> >>(8) you made a typo
> >>I have also proven to connect me to the db from the command
> prompt
> >>with the login information and I connect myself well:
> >>psql pruebapostgis -U postgres
> >>somebody knows which is the problem, it seems that it
> doesn't
> >>transfer localhost to an address, I have also proven with
> 127.0.0.1
> >>and neither it works
> >> From: /Prashanth Ram <pram123 at gmail.com>/
> >> Reply-To: /pram at pramcentral.com,PostGIS Users
> Discussion
> >> <postgis-users at postgis.refractions.net>/
> >> To: /PostGIS Users Discussion
> >> Subject: /Re: [postgis-users] Problem with
> mapserver-postgis/
> >> Date: /Sat, 15 Oct 2005 17:47:06 -0400/
> >> Juan:
> >> Have you tried connecting to the db from the command
> prompt
> >>with
> >> the login information?
> >> Also, the connection string is missing the password
> >> -Prashanth
> >> -- HTMLX.com
> >> Mapserver Hosting, Mapscript Hosting, PHP Hosting
> >> PostgreSQL w/PostGIS extension enabled Hosting
> >> On 10/15/05, *Juan Barón* <jbarong at hotmail.com
> >> <mailto:jbarong at hotmail.com>> wrote:
> >>Hello list,
> >>I am using mapserver 4.4.1 and postgresql 8.0 with postgis.
> >> I have a layer in the map file:
> >> LAYER
> >> CONNECTIONTYPE postgis
> >> NAME callejero
> >> CONNECTION "user=postgres dbname=pruebapostgis
> >>host=localhost
> >> port=5432"
> >> DATA "the_geom from tablacallejero"
> >> STATUS DEFAULT
> >> TYPE LINE
> >> CLASS
> >> COLOR 255 0 0
> >> END
> >> END
> >> and when I execute the application, the layer
> doesn't
> >>appear me and the
> >> result is a message for screen:
> layer
> >>named
> >> 'callejero'.
> connection
> >>to DB
> >> with
> >> connect string 'user=postgres dbname=pruebapostgis
> >>host=localhost
> >> port=5432'.
> >>"localhost" to
> >> address:
> >> Unknown host '.
> to the
> >>specified
> >> postgresql server.
> connection
> >>string
> >>postmaster
> port -
> >>if its
> >> not on
> >>webserver
> >> (usually
> >>postmaster
> postmaster
> >>is on a
> >> different
> >> machine
> >> (8) you made a typo
> >> I have proven to change localhost for 127.0.0.1
> >> <http://127.0.0.1/>, but the result is the
> >> same one.
> >> postgresql this being executed, because if I put
> netstat -
> >>na
> >> appears:
> >> TCP 127.0.0.1:5432
> <http://127.0.0.1:5432/> LISTENING
> >> I don't know which is the problem.
> >> Thank's
> >> postgis-users mailing list
> >> <mailto:postgis-users at postgis.refractions.net>
> >>http://postgis.refractions.net/mailman/listinfo/postgis-users
> >> -- HTMLX.com
