[postgis-users] Problem with mapserver-postgis
Paul Scott pscott at uwc.ac.za
Sun Oct 16 20:44:36 PDT 2005
Change the bit that says md5 to trust and restart the server. That
should allow all ipv4 connections to the server from localhost.
--Paul
On Sun, 2005-10-16 at 19:57 +0000, Juan Barón wrote:
> I have in the file pg_hba.conf the following one it lines:
> host    all         all         127.0.0.1/32          md5
> and I have proven to not putting the password in the connection string
> but the result is the same one, that is to say, it doesn't work and it
> shows the same message:
> msDrawMap(): Image handling error. Failed to draw layer named
> 'callejero'.
> msPOSTGISLayerOpen(): Query error. couldnt make connection to DB with
> connect string 'user=postgres dbname=pruebapostgis'.
> Error reported was 'could not translate host name "localhost" to
> address: Unknown host '.
> This error occured when trying to make a connection to the specified
> postgresql server.
> Most commonly this is caused by
> (1) incorrect connection string
> (2) you didnt specify a 'user=...' in your connection string
> (3) the postmaster (postgresql server) isnt running
> (4) you are not allowing TCP/IP connection to the postmaster
> (5) your postmaster is not running on the correct port - if its not on
> 5432 you must specify a 'port=...'
> (6) the security on your system does not allow the webserver (usually
> user 'nobody') to make socket connections to the postmaster
> (7) you forgot to specify a 'host=...' if the postmaster is on a
> different machine
> (8) you made a typo
>         ______________________________________________________________
>         From:  Paul Scott <pscott at uwc.ac.za>
>         Reply-To:  PostGIS Users Discussion
>         <postgis-users at postgis.refractions.net>
>         Subject:  Re: [postgis-users] Problem with mapserver-postgis
>         Date:  Sun, 16 Oct 2005 21:11:49 +0200
>         >Have you checked your pg_hba.conf that the localhost or
>         127.0.0.1 entry
>         >is a trusted user? If not try setting the ident part to trust
>         and
>         >restart the server.
>         >--Paul
>         >On Sun, 2005-10-16 at 18:55 +0000, Juan Barón wrote:
>         > > I have pulled up postmaster with - i  and it continues
>         without working
>         > >         From:  Armin Burger <armin.burger at gmx.net>
>         mapserver-postgis
>         > >         Date:  Sun, 16 Oct 2005 12:57:56 +0200
>         > >         >Is postmaster started with the -i option (enable
>         TCP/IP
>         > >         >connections)?
>         > >         >Armin
>         > >         >Juan Barón wrote:
>         > >         >>Hi:
>         > >         >>I have changed the connection string writing the
>         password:
>         > >         >>CONNECTION "user=postgres password=postgres
>         > >         >>host=localhost port=5432"
>         > >         >>and I obtain the same result:
>         draw layer
>         > >         named
>         > >         >>'callejero'.
>         connection
>         > >         to DB
>         > >         >>with connect string 'user=postgres
>         password=postgres
>         > >         >>dbname=pruebapostgis host=localhost port=5432'.
>         name
>         > >         "localhost" to
>         connection to the
>         > >         >>specified postgresql server.
>         connection string
>         running
>         the postmaster
>         correct port - if
>         > >         its not
>         > >         >>on 5432 you must specify a 'port=...'
>         the
>         > >         webserver
>         > >         >>(usually user 'nobody') to make socket
>         connections to the
>         > >         >>postmaster
>         postmaster is
>         > >         on a
>         > >         >>different machine
>         > >         >>(8) you made a typo
>         > >         >>I have also proven to connect me to the db from
>         the command
>         > >         prompt
>         > >         >>with the login information and I connect myself
>         well:
>         > >         >>psql  pruebapostgis  -U postgres
>         > >         >>somebody knows which is the problem, it seems
>         that it
>         > >         doesn't
>         > >         >>transfer localhost to an address, I have also
>         proven with
>         > >         127.0.0.1
>         > >         >>and neither it works
>         > >         >>     From:  /Prashanth Ram <pram123 at gmail.com>/
>         > >         >>     Reply-To:  /pram at pramcentral.com,PostGIS
>         Users
>         > >         Discussion
>         > >         >>     <postgis-users at postgis.refractions.net>/
>         > >         >>     To:  /PostGIS Users Discussion
>         > >         >>     Subject:  /Re: [postgis-users] Problem with
>         > >         mapserver-postgis/
>         > >         >>     Date:  /Sat, 15 Oct 2005 17:47:06 -0400/
>         > >         >>     Juan:
>         > >         >>        Have you tried connecting to the db from
>         the command
>         > >         prompt
>         > >         >>with
>         > >         >>     the login information?
>         > >         >>       Also, the connection string is missing
>         the password
>         > >         >>     -Prashanth
>         > >         >>     --     HTMLX.com
>         > >         >>     Mapserver Hosting, Mapscript Hosting, PHP
>         Hosting
>         > >         >>     PostgreSQL w/PostGIS extension enabled
>         Hosting
>         > >         >>     On 10/15/05, *Juan Barón*
>         <jbarong at hotmail.com
>         > >         >>     <mailto:jbarong at hotmail.com>> wrote:
>         > >         >>Hello list,
>         > >         >>I am using mapserver 4.4.1 and postgresql 8.0
>         with postgis.
>         > >         >>         I have a layer in the map file:
>         > >         >>         LAYER
>         > >         >>           CONNECTIONTYPE postgis
>         > >         >>             NAME callejero
>         > >         >>host=localhost
>         > >         >>         port=5432"
>         > >         >>             DATA "the_geom from tablacallejero"
>         > >         >>             STATUS DEFAULT
>         > >         >>             TYPE LINE
>         > >         >>             CLASS
>         > >         >>              COLOR 255 0 0
>         > >         >>             END
>         > >         >>         END
>         > >         >>         and when I execute the application, the
>         layer
>         > >         doesn't
>         > >         >>appear me         and the
>         > >         >>         result is a message for screen:
>         Failed to draw
>         > >         layer
>         > >         >>named
>         > >         >>         'callejero'.
>         couldnt make
>         > >         connection
>         > >         >>to DB
>         > >         >>         with
>         > >         >>host=localhost
>         > >         >>         port=5432'.
>         host name
>         > >         >>"localhost" to
>         > >         >>         address:
>         > >         >>         Unknown host '.
>         a connection
>         > >         to the
>         > >         >>specified
>         > >         >>         postgresql server.
>         your
>         > >         connection
>         > >         >>string
>         isnt running
>         connection to the
>         > >         >>postmaster
>         the correct
>         > >         port -
>         > >         >>if its
>         > >         >>         not on
>         not allow the
>         > >         >>webserver
>         > >         >>         (usually
>         connections to the
>         > >         >>postmaster
>         if the
>         > >         postmaster
>         > >         >>is on a
>         > >         >>         different
>         > >         >>         machine
>         > >         >>         (8) you made a typo
>         > >         >>         I have proven to change localhost for
>         127.0.0.1
>         > >         >>         <http://127.0.0.1/>, but the result is
>         the
>         > >         >>         same one.
>         > >         >>         postgresql this being executed, because
>         if I put
>         > >         netstat -
>         > >         >>na
>         > >         >>         appears:
>         > >         >>         TCP 127.0.0.1:5432
>         > >         <http://127.0.0.1:5432/>  LISTENING
>         > >         >>         I don't know which is the problem.
>         > >         >>         Thank's
>         > >         >>         postgis-users mailing list
>         <mailto:postgis-users at postgis.refractions.net>
>         >>http://postgis.refractions.net/mailman/listinfo/postgis-users
>         > >         >>     --     HTMLX.com
>         Hosting
>         Hosting
