[postgis-users] dropping bboxes doesn't work ?!
strk at refractions.net
Mon Oct 17 01:46:53 PDT 2005
I get correct result with current CVS:
SELECT hasbbox('LINESTRING(0 0, 1 1)');
t
SELECT hasbbox(dropbbox('LINESTRING(0 0, 1 1)'));
f
Are you using an updated version ? (1.1.0CVS is a development
and changing version).
--strk;
On Mon, Oct 17, 2005 at 10:28:05AM +0200, "R. Müller" wrote:
> Hallo,
> i had to change the coordinate system for one table. after doing this,
> all geometries kept their old boxes in cache, so i tried to drop the
> bboxes dropbbox(), but obviously this operation failed since all
> geometries still kept their bbox in cache (i checked this with
> hasbbox()). the dropbbox()-operation returned a list with the 'right'
> bboxes, but no further comment.
> "POSTGIS="1.1.0CVS" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004"
> USE_STATS DBPROC="0.3.1" RELPROC="0.3.1""
> Gentoo-Installation
> i' dont think that it is a authorizations problem, becaus i'm the owner
> of this table.
> any hint ?
> or is there another approach for renewing the bboxes ?
> thanks
> ronald
> postgis-users mailing list
