[postgis-users] dropping bboxes doesn't work ?!
"R. Müller" r.mueller at unicomp-berlin.de
Mon Oct 17 02:32:34 PDT 2005
Markus Schaber wrote:
> Could you try
> UPDATE geotable SET geom=dropbbox(geom);
> and tell us whether your problem remains?
thanks a lot, it works .... ;-)
but in this case it shouldn't it work for the select-query as well ?
the bbox is not a value, which is directly stored in the table or
visible for the user respectively.
but ok, good to know
ronald
