[postgis-users] Query performance issue
Robert Burgholzer
rburghol at chesapeakebay.net
Mon Oct 17 07:05:41 PDT 2005
So what do queries A-D look like? (or were they in a previous post)?
r.b.
On Mon, 2005-10-17 at 00:16, Stephen Woodbridge wrote:
> I want to thank everyone for their help, suggestions and in general all
> the support I got from the list. Here are the results:
> I had to do 4 updates like the following:
> update streets set boundary=b.name from polygon_layer b
> where
> streets.the_geom && b.the_geom
> and
> intersects(streets.the_geom, b.the_geom)
> streets has just under 2 million records
> the polygon_layers and run times follow. The size of the polygons in
> spatial area decrease from A -> D
> layer| #poly | time hr | function
> A | 14 | * | n/a
> B | 230 | 30 | intersects()
> C | 3991 | 33 | distance() <=0
> D | 2432 | 3 | intersects()
> I tried A first and aborted it after to separate 15 hr runs and
> ultimately solve that one a different way by updating the records based
> on min and max gid values. After have some success with D, I decided to
> run the others and see how long it took.
> I guess I should look at the GEOS code and see how it works. Does anyone
> know if it uses the Sutherland line clipping algorithm which is probably
> the fastest way to test if two segments intersect without computing the
> intersection.
> Anyway, Thanks again everyone.
> -Steve
> postgis-users mailing list
Non-point Source Data Analyst
University of Maryland, College Park
Chesapeake Bay Program Office
410 Severn Avenue, Suite 305B
Annapolis, MD, 21403
Phone: (410) 267-5779
