[postgis-users] polygon points
Guido Lemoine guido.lemoine at jrc.it
Tue Oct 18 00:27:54 PDT 2005
Try:
  select pointn(ExteriorRing(polygon_geom), n) from poly_table
and loop through n (1 .. npoints(ExteriorRing(polygon_geom))
Extend to interiorrings, if relevant. Use the X() function to get at the
X-coordinate to check.
GL
Frances Collier wrote:
> Hello all,
> Is there a function that can get the individual points from a polygon
> geometry? I am trying to find all the points in the wkb_geometry that
> matches with a particular X value.
> Thank you for any help.
> -Frances Collier
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
