[postgis-users] RE: libpostgis library
Ethan Alpert
ealpert at digitalglobe.com
Tue Oct 18 10:09:28 PDT 2005
Which was #2 on my list of the top 4 reasons a layer doesn't display.
-e
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Frances Collier
Sent: Tuesday, October 18, 2005 10:35 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] RE: libpostgis library
Thanks for the hint, Markus.
I never did check the actual SRID since I was trying to mix a database
layer with some shapefiles in the mapserver. However, the SRID comment
got me thinking about projections and that's what my problem was. My
database layer and the shapefiles were not in the same projection. It's
working better now.
Thank you,
Frances Collier
Date: Mon, 17 Oct 2005 10:55:28 +0200
Subject: Re: [postgis-users] Re: libpostgis library
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Message-ID: <43536700.8010401 at logix-tt.com>
Content-Type: text/plain; charset=windows-1252
Hi, Frances,
Frances Collier wrote:
> I have the liblwgeom.dll, however, it is not in the Win32 directory
> (it is in the PostgreSQL\8.0\lib directory). Do I need to put it there
> for PostGIS to return the data to mapserver properly?
No, this is the correct directory for PostgreSQL extensions like
PostGIS.
> After running SELECT postgis_full_version() I got: POSTGIS=1.0.1
> GEOS=2.1.4 PROJ=Rel. 4.4.9, 29 Oct 2004 USE_STATS DBPROC=0.3.0
> RELPROC=0.3.0
This output tells us that your PostgreSQL has successfully found the
liblwgeom.dll, and works with it.
Thus, the problem has to be somewhere else, maybe your MapServer query
definition.
Does Mapserver return any error messages? What SRID is your data in, and
what does Mapserver expect?
Maybe the Mapserver experts here or on the Mapserver list can give you
more help.
Markus
postgis-users mailing list postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
