[postgis-users] Extent on multiple tables
strk at refractions.net
Fri Oct 21 03:21:53 PDT 2005
You might try:
select extent(g) from (
select the_geom from table1
union all
select the_geom from table2
) as foo;
Consider also using the estimated_extent() function, which should
give you a much faster result.
--strk;
On Fri, Oct 21, 2005 at 12:00:17PM +0200, Lars Rößiger wrote:
> Hello,
> is there a possibility to use the Extent-function on multiple tables in
> one query? My map layers (built-up areas, waterlines, etc.) are in
> separate tables, but to build the map I need to know the cumulative
> Extent of all layers. I tried INNER JOIN and even subselects within the
> Extent-function -- without success.
> Thank you,
> Lars
> postgis-users mailing list
