[postgis-users] mapserver db connection
Markus Schaber schabi at logix-tt.com
Tue Oct 25 04:55:47 PDT 2005
Hi, Gregory,
Gregory S. Williamson wrote:
>> The tables are all indexed using gist and recently analyzed. I have
>> not read anything about geometry stats. Is that another version?
> The earlier versions of postGIs used a seperate command to gather
> statistics -- in the 1.x series this is done by the "analyze"
> command, so it sounds like that's ok.
This only works if your PostgreSQL is >= 8.0, if you use a 7.X variant,
you still need to use the "update_geometry_stats()" mechanism as they
don't provide the hooks for PostGIS to plug into the statistics system.
But as frances runs PostgreSQL 8.04, this should not be the problem.
>> Also, what is the fastCGI? I'm still learning about all this stuff
>> and obviously have much more to learn!
> I've not used it but check the MMS archives for information about
> fast cgi -- in some environments it can make a real difference. Sorry
> I can't provide more insight there.
I think that the main advantage of fastGCI is that it does keep some
ressources between adjacent HTTP Requests, e. G. the SQL connection.
Dropping and re-establishing SQL connections needs a lot of time, so
there are some techniques (e. G. connection pooling) to circumvent this.
Markus
