[postgis-users] help command pgsql2shp
zourite at cegetel.net
Tue Oct 25 09:30:23 PDT 2005
It would be great but that's not so easy
this is my pgsql2shp version exe
RCSID: $Id: pgsql2shp.c,v 1.74.2.4 2005/07/22 19:20:49 strk Exp $
USAGE: pgsql2shp [<options>] <database> [<schema>.]<table>
pgsql2shp [<options>] <database> <query>
And this is the original command who doesn't work
c:\PostgreSQL\8.0.3\bin>pgsql2shp -f c:\test.shp testgis 'select * from LT
where gid = 82'
Initializing... Querying for attributes: ERROR: syntax error at or near
"Select" at character 152
Even if i use -g the_geom option
Thanks
Vive la reunion ile intense
Fé pété
> where name = 'XXX'
> you lack proper quoting
> --strk;
> On Tue, Oct 25, 2005 at 05:28:36PM +0200, zourite at cegetel.net wrote:
>> Hello
>> Is anyone can give me an example of pgsql2shp command with sql query in
>> option. Is there a documentation of this function (may be i could write
>> it).
>> I'm looking for something like this :
>> pgsql2shp -f c:\test.shp testgis 'select * from LT where name = XXX' but
>> it doesn't work !
>> Thanks
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
