[postgis-users] JTS -- was Re: Transform Performance
Robert Burgholzer
rburghol at chesapeakebay.net
Wed Oct 26 14:46:42 PDT 2005
With regard to general performance, are the performance hits due to
execution of java functions?
I ask because, I think I found that the intersection() function seems to
be java based (in JTS). Is this a correct interpretation of what is
going on? I suppose I could just RTFLA (the friendly list archives that
is), as I recall the topics of porting java functions to postgis. I had
understood that this was the porting of java to C++, but perhaps that is
untrue. Anyone that can clarify this?
r.b.
On Wed, 2005-10-26 at 16:17, Charlie Savage wrote:
> Very interesting. Following your lead I created this function and then
> ran it through the scenarios you discuss below.
> CREATE OR REPLACE FUNCTION
> testme(value int) RETURNS int
> AS $$
> BEGIN
> RAISE INFO 'testme: %', value;
> RETURN value;
> END;
> LANGUAGE plpgsql IMMUTABLE;
> I thought, but was wrong, that in this case the function would only be
> called once:
> select testme(MyField) from MyTable;
> I had hoped that Postgresql would cache the value of the input
> parameter, see that testme had already been invoked for that parameter,
> and skip the evaluation. However, it does not, the method get called
> for every record. From the Postgresql docs (emphasis is mine):
> "An IMMUTABLE function cannot modify the database and is guaranteed to
> return the same results given the same arguments forever. This category
> allows the optimizer to pre-evaluate the function when a query calls it
> with *constant* arguments."
> > POSSIBLE OPTIMIZATIONS
> > First optimization that comes to mind is reducing scans by making
> > outer-level get_proj4_from_srid() calls take a constant argument:
> > transform_geometry(g, get_proj4_from_srid(find_srid(..)),
> > get_proj4_from_srid(4326));
> Perhaps a quick simple way to do this is to create an overloaded version
> of transform that takes both the source srs and targer srs as constants.
> That would get rid of all the SRID calls, and all but two of the
> get_proj4_from_srid calls. Thus it would be a lot faster, but not much
> harder to use.
> Thanks,
> Charlie
> postgis-users mailing list
Non-point Source Data Analyst
University of Maryland, College Park
Chesapeake Bay Program Office
410 Severn Avenue, Suite 305B
Annapolis, MD, 21403
Phone: (410) 267-5779
