[postgis-users] adding customized projection definitions to spatial_ref_sys_table
Matthew Perry
perrygeo at gmail.com
Thu Oct 27 11:21:17 PDT 2005
Chris,
Check out http://www.remotesensing.org/geotiff/proj_list/stereographic.html.
You might try translating those projection parameters in addition to +datum
and +units to define this projection.
matt
On 10/27/05, christian.michels at eifelgeist.com <
christian.michels at eifelgeist.com> wrote:
> Hello Together,
> Since I am using customized projections I need to create my own projection
> definition in the spatial_ref_sys_table - but I do not really know how it
> works.
> What I have is a ESRI prj file projection definition like:
> PROJCS["Custom",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137,
> 298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295
> ]],PROJECTION["Stereographic"],PARAMETER["False_Easting",0],PARAMETER["False_Northing",0],PARAMETER["Central_Meridian",0],UNIT["Meter",1]]
> Looks a bit like the srtext - but how do I get the definition for the
> proj4text entry ?
> Any help is very much appreciated !
> Cheers
> Chris
> postgis-users mailing list
Matt Perry
http://www.perrygeo.net
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051027/b062e4cb/attachment.html>
