[postgis-users] postgis through views
Craig Miller craig.miller at spatialminds.com
Thu Oct 27 16:15:22 PDT 2005
Your view isn't listed as a spatial data table yet, so PostGIS can't *see*
it.
--Craig
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Eric
Hanson
Sent: Thursday, October 27, 2005 1:38 PM
To: postgis-users at postgis.refractions.net; consultants at pdx.edu
Subject: [postgis-users] postgis through views
We're trying to use PostGIS through a VIEW with Mapserver.  We have two
identical tables, one being accessed natively and one through a VIEW with
CREATE VIEW r200408_wet_fill as select * from r2004_wet_fill.
Things seem to not be working.  Are there any known problems for using
VIEWs with PostGIS?
Thanks,
Eric
[client 24.22.56.63] PHP Warning:  [MapServer Error]: msDrawMap():
Failed to draw layer named 'Wetlands'.\n in
/n/fs.research.pdx.edu/disk/resuser01/u/elhanson/public_html/oscdl/map.php
on line 281, referer:
http://geospatial.research.pdx.edu:1025/~elhanson/oscdl/
prepare_database(): Error executing POSTGIS DECLARE (the actual query)
statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from
r200408_wet_fill WHERE the_geom && setSRID('BOX3D(7477447.5409836
540799.999999963,7865352.4590164 811999.99999998)'::BOX3D,
find_srid('','r200408_wet_fill','the_geom') )' <br><br>\n\nPostgresql
reports the error as 'ERROR:  column "oid" does not
exist\n'<br><br>\n\nMore Help:<br><br>\n\nError with POSTGIS data
variable. You specified '<check your .map file>'.<br>\nStandard
ways of specifiying are : <br>\n(1) 'geometry_column from
geometry_table' <br>\n(2) 'geometry_column from (<sub query>) as
foo using unique <column name> using SRID=<srid#>'
<br><br>\n\nMake sure you put in the 'using unique  <column name>'
and 'using SRID=#' clauses in.\n\n<br><br>For more help, please see
http://postgis.refractions.net/documentation.php
\n\n<br><br>Mappostgis.c - version of Jan 23/2004.\n\n in
[client 24.22.56.63] PHP Fatal error:  Call to a member function
saveImage() on a non-object in
on line 285, referer:
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
