[postgis-users] postgis through views
Lionel Bargeot
l.bargeot at educagri.fr
Thu Oct 27 23:44:57 PDT 2005
in mapfile, you have to "help" Mapserver to find a unique column and a
SRID for the view.
If you use a view, you have lost
- oid as writen in prvious mail
- srid
This is the usual information mapserver find in the geometry-column table.
In the layer section , you will have to define the data parameter like
this :
DATA "geom from r200408_wet_fill" USING UNIQUE oid USING SRID=your_srid
oid must be added in the view definition (or any other unique item.
regards
Lionel
PostGIS Users Discussion <postgis-users at postgis.refractions.net> le
Vendredi, Octobre 28, 2005 à 2:31 AM a écrit :
>> We're trying to use PostGIS through a VIEW with Mapserver. We have two
>> identical tables, one being accessed natively and one through a VIEW
>with
>> CREATE VIEW r200408_wet_fill as select * from r2004_wet_fill.
>> Things seem to not be working. Are there any known problems for using
>> VIEWs with PostGIS?
>Postgres (generally) uses an internal column (oid) in each table to
>uniquely
>number each row. Unless explicitly stated, your view will not have the oid
>column. From the mapserver error message, it suggests that mapserver uses
>this
>column, hence the error with your view.
>So create your view as:
>CREATE VIEW r200408_wet_fill as select oid, * from r2004_wet_fill
>to ensure your view contains the oid column.
>I don't know this for sure, but if mapserver uses the oid, there may be
>some
>performance benefits to indexing the oid column in the underlying table.
>Does
>anyone know this for sure? (Postgres does NOT index the oid by default).
>One other aspect of views on spatial tables relates to the
>geometry_columns
>table. When you add a spatial (geometry) column to a table, an entry in
>the
>geometry_columns table is created, which describes the new spatial
>column. Your
>view will not have an entry in this table (but the underlying table will).
>I don't know about mapserver, but some applications do refer to this
>table to
>identify tables with geometry columns. So creating an entry in this table
>for
>your spatial views may also resolve some problems.
>Cheers,
> Brent Wood
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Lionel Bargeot
Agrogeomatic 03.80.77.28.49 http://www.igcs-stb.org/
4 rue Champs-prevois, bat grand-champs, 21000 Dijon
