[postgis-users] Buffer bug ?
strk at refractions.net
Wed Sep 7 11:03:09 PDT 2005
Ok, I downloaded your test case and tried comparing JTS,
GEOS-2.1.4 and GEOS-1.0.0.
I used PostGIS version 1.1.0CVS as test interface.
Nothing changed in collect() and npoints() since PostGIS-1.0.3,
so results should be about the same in the two versions.
The query is:
-- ### is Number of features
SELECT npoints(buffer(collect(geom), 1000))
FROM ( select lga_geom as geom from lg_annee limit ### ) as foo;
Number of features: 200 (1106 input points in collected MultiPolygon)
[JTS-1.7] output_points 1754
real 0m8.705s
[GEOS-2.1.4] output_points 1816
real 0m5.594s
[GEOS-1.0.0] output_points 1735
real 0m16.450s
Number of features: 400 (2320 input points in collected MultiPolygon)
[JTS-1.7] output_points 1897
real 1m3.761s
[GEOS-2.1.4] output_points 1959
real 0m43.020s
[GEOS-1.0.0] output_points 1912
real 6m50.783s
Number of features: 1000 (5992 input points in collected MultiPolygon)
[JTS-1.7] output_points 2598
real 9m20.873s
[GEOS-2.1.4] output_points 2618
real 10m54.414s
[GEOS-1.0.0]
KILLED AFTER:
real 94m14.421s
I don't really understand why number of output points change, anyway
the test shows that GEOS-2.1.4 is *much* faster then GEOS-1.0.0
(and sometimes faster then JTS-1.7). For 1000 features GEOS-1.0.0
is completely stuck after 94 Minutes !!
So, to conclude, I could not verify the reported bug.
I suggest you update GEOS to version 2.1.4 and PostGIS
to the upcoming 1.0.4 release. Then, if you can reproduce the
OLD vs. NEW performance loss problem yourself, please provide a
*simple* test case.
As for killing GEOS during operation this is an old and known
problem we might approach soon or late, but it is not first
priority at the moment.
--strk;
On Mon, Aug 29, 2005 at 11:28:13AM +0200, Daniel wrote:
> Yes: it's harder for the whole community when you're away ! ;-)
> My dataset is about 5 Mo, so I would not post it on a public list ...
> Can I upload it on a server and give you a private access ?
> I tried tests on reduced datasets, too: it works, but very slowly. Far
> much slowly than with earlier versions. The execution time is
> exponential. For example:
> 100 features: 303 ms
> 200 : 2478 ms
> 500 : 34690 ms
> With our first implementation (firsts postgis versions with geos), we
> got about 25 seconds for 7500 features.
> Sincerely yours,
> dF
> strk at refractions.net wrote:
> >On Fri, Aug 26, 2005 at 04:33:27PM +0100, Mark Cave-Ayland wrote:
> >>Unfortunately I'm now away from work for at least a week, but I hope that
> >>someone else on the list will be able to give you some help in the
> >>meantime.
> >Hello guys, it looks like I'm missing something here...
> >Daniel, would you post a test case for me to check out ?
> >A reduced case working on your old setup and hanging
> >on the new one ?
> >--strk;
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
