[postgis-users] cannot retrieve any geometric data
david techer
davidtecher at yahoo.fr
Sun Sep 11 11:40:48 PDT 2005
Hi Orkun
Did U try ogr2ogr to import the data?
So U have to use the schema public for your data
Regards
David
orkun wrote:
> hello
> I cannot retrieve any geometric data with any select command :
> select distinct(cat),astext(wkb_geometry) as geometry from jeopgis
> gives nothing.
> here is my postgis structure:
> bzk=# \d jeopgis
> Table "public.jeopgis"
> Column | Type | Modifiers
> ogc_fid | integer | not null default
> nextval('public.jeopgis_ogc_fid_seq'::text)
> wkb_geometry | geometry |
> cat | integer |
> label | character varying |
> Indexes:
> "jeo_gidx" gist (wkb_geometry)
> Check constraints:
> "enforce_srid_wkb_geometry" CHECK (srid(wkb_geometry) = 1)
> "enforce_dims_wkb_geometry" CHECK (ndims(wkb_geometry) = 2)
> "enforce_geotype_wkb_geometry" CHECK (geometrytype(wkb_geometry) =
> 'POLYGON'::text OR wkb_geometry IS NULL)
> what might be the problem ?
> regards
> Ahmet Temiz
> ______________________________________
> XamimeLT - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the
> sender's own
> and do not necessarily represent the views and the opinions of
> Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
> olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
> nitelikte degildir.
> postgis-users mailing list
___________________________________________________________________________
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
Téléchargez cette version sur http://fr.messenger.yahoo.com
