[postgis-users] distance and intersection with 3d geometries
strk at refractions.net
Mon Sep 12 08:40:56 PDT 2005
distance() is a 2d only function
--strk;
On Mon, Sep 12, 2005 at 04:37:36PM +0200, Joaquin Jose del Cerro Murciano wrote:
> Hi all,
> I am having some trouble getting distance to work correctly with 3d
> geometries.
> I have tried with a "select" simple to see as it worked.
> The results are not those that hoped.
> I do not understand it.
> $ uname -a
> FreeBSD Silvanesti 5.4-RELEASE FreeBSD 5.4-RELEASE #0: Mon May 23 12:17:48
> CEST 2005 root at Silvanesti:/usr/obj/usr/src/sys/MYKERNEL i386
> $ psql -d dister05
> Welcome to psql 7.4.7, the PostgreSQL interactive terminal.
> Type: \copyright for distribution terms
> \h for help with SQL commands
> \? for help on internal slash commands
> \g or terminate with semicolon to execute query
> \q to quit
> dister05=# select postgis_full_version();
> POSTGIS="1.0.0RC3" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS DBPROC="0.2.0"
> RELPROC="0.2.0"
> (1 row)
> ister05=# select
> dister05-# distance(
> dister05(# MakeLine(MakePoint(200,200), MakePoint(400,200)),
> dister05(# MakeLine(MakePoint(300,100), MakePoint(300,300))
> dister05(# )::int as A_Expected0, -- expected 0, ok
> dister05(# MakeLine(MakePoint(200,200,10), MakePoint(400,200,10)),
> dister05(# MakeLine(MakePoint(300,100,10), MakePoint(300,300,10))
> dister05(# )::int as B_Expected0, -- expected 0, ????
> dister05(# MakeLine(MakePoint(200,200, 0), MakePoint(400,200, 0)),
> dister05(# MakeLine(MakePoint(300,100,100), MakePoint(300,300,100))
> dister05(# )::int as C_Expected100, -- expected 100, ????
> dister05(# MakeLine(MakePoint(200,200,0), MakePoint(400,200,100)),
> dister05(# MakeLine(MakePoint(300,100,0), MakePoint(300,300,100))
> dister05(# )::int as D_Expected50 -- expected 50 aprox., ????
> dister05-# ;
> a_expected0 | b_expected0 | c_expected100 | d_expected50
> 0 | 26 | 0 | 28
> (1 row)
> dister05=#
> The second column is the same that first but with an elevation of 10 (z=10).
> Because it is not zero?
> In the third column the lines are not crossed in the space.
> The lines are in different planes (z=0, z=100).
> That I can be making bad?
> Best regards,
> Joaquin
> P.S. Sorry for my terrible English.
> ______________________________________________
> Renovamos el Correo Yahoo!
> Nuevos servicios, más seguridad
> http://correo.yahoo.es
> postgis-users mailing list
