[postgis-users] distance and intersection with 3d geometries
strk at refractions.net
Mon Sep 12 13:17:04 PDT 2005
On Mon, Sep 12, 2005 at 10:00:04PM +0200, Joaquin Jose del Cerro Murciano wrote:
> > distance() is a 2d only function
> > --strk;
> intersection() is a 2d only function ?
Depending on GEOS version.
Since GEOS-2.1.1 intersection() somehow supports 3d.
Version 2.1.2 contains a fix in it.
Polygon 3d intersection is very fuzzy.
> Where I can consult that functions are 2d or 3d ?
Currently nowhere.
Should be in the postgis manual though... if you can
file a bug report for this I'll eventually handle it.
--strk;
