[postgis-users] within/contains
Matthew Perry
perrygeo at gmail.com
Thu Sep 15 01:40:12 PDT 2005
Nicol,
On 9/15/05, Nicol Hermann <postgis at geoworld.de> wrote:
> i wonder why the following statements returns different results:
> select within(GeomFromText('POLYGON((10 10,30 10,30 20,10 20,10 10))',
> -1), GeomFromText('POLYGON((0 0, 40 0, 40 30, 30 0, 0 0))', -1) );
> => FALSE
If you are trying to test intesections between two rectangles, I believe you
have your X&Y switched in the 4th coordinate of your second geometry:
instead of:
=> FALSE
it should be:
select within(GeomFromText('POLYGON( (10 10,30 10,30 20,10 20,10 10))',
-1), GeomFromText('POLYGON((0 0, 40 0, 40 30, 0 30, 0 0))', -1) );
=> TRUE
According to the original geometry as defined in your query, geos was
returning the correct result. (A simple sketch on graph paper will show you
why... does anyone use graph paper anymore or am I the only one ??)
Matt Perry
http://www.perrygeo.net
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050915/7b5e974b/attachment.html>
