[postgis-users] a line' s direction
Hartmut Tschauner
hartmut.tschauner at gmail.com
Thu Sep 15 02:15:22 PDT 2005
Hi Ahmet,
The function below will calculate the azimuth between two points. You would
pass the start and end points to get the direction of a line. I attach a SQL
script that you can execute to create the function in your database.
Cheers,
Hartmut
Hartmut Tschauner
Department of Archaeology
Seoul National University
Gwanak-Gu Sillim 9-dong San 56-1
Seoul, 151-742
Korea
ph. +82 (2) 880-9260
CREATE OR REPLACE FUNCTION public.azimuth(geometry, geometry)
RETURNS float8 AS
DECLARE
geom1 ALIAS FOR $1;
geom2 ALIAS FOR $2;
geom2trans geometry;
BEGIN
IF geom1 IS NULL OR geom2 IS NULL THEN
RETURN NULL;
ELSE
IF isempty(geom1) OR isempty(geom2) OR geometrytype(geom1) != \'POINT\' OR
geometrytype(geom2) != \'POINT\' THEN
RETURN NULL;
END IF;
END IF;
IF srid(geom1) != -1 AND srid(geom2) != srid(geom1) THEN
geom2trans := transform(geom2, srid(geom1));
ELSE
geom2trans := geom2;
END IF;
IF x(geom1) = x(geom2trans) AND y(geom1) < y(geom2trans) THEN
RETURN 0;
ELSIF x(geom1) = x(geom2trans) AND y(geom1) > y(geom2trans) THEN
RETURN 180;
ELSIF y(geom1) = y(geom2trans) AND x(geom1) < x(geom2trans) THEN
RETURN 90;
ELSIF y(geom1) = y(geom2trans) AND x(geom1) > x(geom2trans) THEN
RETURN 270;
ELSIF x(geom1) < x(geom2trans) AND y(geom1) < y(geom2trans) THEN
RETURN degrees(atan(abs(x(geom1) - x(geom2trans)) / abs(y(geom1) -
y(geom2trans))));
ELSIF x(geom1) < x(geom2trans) AND y(geom1) > y(geom2trans) THEN
RETURN degrees(atan(abs(y(geom1) - y(geom2trans)) / abs(x(geom1) -
x(geom2trans)))) + 90;
ELSIF x(geom1) > x(geom2trans) AND y(geom1) > y(geom2trans) THEN
y(geom2trans)))) + 180;
ELSIF x(geom1) > x(geom2trans) AND y(geom1) < y(geom2trans) THEN
x(geom2trans)))) + 270;
ELSE
RETURN 0;
END IF;
END;
LANGUAGE 'plpgsql' VOLATILE;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050915/1491effe/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050915/1491effe/attachment.ksh>
