[postgis-users] importing shape files nightmare!
strk at refractions.net
Thu Sep 15 03:36:35 PDT 2005
Attached is a patch to bring shp2pgsql.c from Revision 1.91
to Revision 1.96 (the one shipped with PostGIS 1.0.4).
If you don't have the sources that's ... well ... sad :(
You can still download latest release sources (1.0.4),
run make in the loader/ directory and replace your dumper/loader
with the newly created ones.
.. you can read by the end of the patch all changes
in shp2pgsql since 1.91 ...
--strk;
On Thu, Sep 15, 2005 at 12:28:25PM +0200, christomec wrote:
> I get:
> RCSID: $Id: shp2pgsql.c,v 1.91 2005/07/04 09:47:03 strk Exp $
> Is there a way of just fixing the shp2pgsql without having to re-emerging
> postgis?
> > On Thu, Sep 15, 2005 at 11:58:29AM +0200, strk at refractions.net wrote:
> >> On Thu, Sep 15, 2005 at 11:52:08AM +0200, christomec wrote:
> >> > So is POSTGIS="1.1.0CVS" is in actual fact 1.0.3?
> >> Might be, the 1.1 and 1.0 are two different branches in CVS,
> >> and 1.1.0CVS is there since about 1.0.0 is out... there's no
> >> easy way to tell which version of the code 1.1.0CVS is.
> >> Since this is a bug with pgsql2shp what you should look at
> >> is RCSID from it. It is shown running pgsql2shp w/out arguments.
> > Oops.. sorry, it's shp2pgsql (the loader), NOT pgsql2shp (the dumper).
> > The RCSID is still shown when called w/out args
> > --strk;
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > !DSPAM:432946b7323981650317341!
Index: shp2pgsql.c
RCS file: /home/cvs/postgis/postgis/loader/shp2pgsql.c,v
retrieving revision 1.91
retrieving revision 1.96
diff -U2 -r1.91 -r1.96
--- shp2pgsql.c 4 Jul 2005 09:47:03 -0000 1.91
+++ shp2pgsql.c 29 Aug 2005 22:36:25 -0000 1.96
@@ -1,4 +1,4 @@
- * $Id: shp2pgsql.c,v 1.91 2005/07/04 09:47:03 strk Exp $
+ * $Id: shp2pgsql.c,v 1.96 2005/08/29 22:36:25 strk Exp $
* PostGIS - Spatial Types for PostgreSQL
@@ -131,5 +131,5 @@
static char rcsid[] =
- "$Id: shp2pgsql.c,v 1.91 2005/07/04 09:47:03 strk Exp $";
+ "$Id: shp2pgsql.c,v 1.96 2005/08/29 22:36:25 strk Exp $";
void *safe_malloc(size_t size)
@@ -436,4 +436,5 @@
int j;
+ SHPObject *obj=NULL;
hSHPHandle = SHPOpen( shp_file, "rb" );
@@ -451,7 +452,15 @@
/* Check we have at least a not-null geometry */
- j=num_entities;
- while( ( obj == NULL || obj->nVertices == 0 ) && j--)
+ for (j=0; j<num_entities; j++)
obj = SHPReadObject(hSHPHandle,j);
+ if ( obj && obj->nVertices > 0 ) {
+ SHPDestroyObject(obj);
+ break;
+ obj=NULL;
if ( obj == NULL)
@@ -763,5 +772,4 @@
else printf("NULL);\n");
- SHPDestroyObject(obj);
return;
@@ -818,5 +826,4 @@
return;
@@ -1157,6 +1164,6 @@
unsigned int u;
- if (dump_format) printf("SRID=%s;POINT(",sr_id);
- else printf("GeometryFromText('POINT (");
+ if (dump_format) printf("SRID=%s;%s(", sr_id, pgtype);
+ else printf("GeometryFromText('%s(", pgtype);
for (u=0;u<obj->nVertices; u++){
@@ -1416,9 +1423,10 @@
char *buf = malloc(256*ring->n);
int i;
+ buf[0] = '\0';
for (i=0; i<ring->n; i++)
- if (i) sprintf(buf, "%s,", buf);
- sprintf(buf, "%s%g %g",
- buf,
+ if (i) strcat(buf, ",");
+ sprintf(buf+strlen(buf), "%g %g",
ring->list[i].x,
ring->list[i].y);
@@ -1517,9 +1525,17 @@
GetFieldsSpec(void)
+ * Shapefile (dbf) field name are at most 10chars + 1 NULL.
+ * Postgresql field names are at most 63 bytes + 1 NULL.
+#define MAXFIELDNAMELEN 64
int field_precision, field_width;
int j, z;
- char name[64];
- char name2[64];
+ char name[MAXFIELDNAMELEN];
+ char name2[MAXFIELDNAMELEN];
DBFFieldType type = -1;
+#ifdef USE_ICONV
+ char *utf8str;
+#endif
num_fields = DBFGetFieldCount( hDBFHandle );
@@ -1529,5 +1545,5 @@
widths = malloc(num_fields*sizeof(int));
precisions = malloc(num_fields*sizeof(int));
- col_names = malloc((num_fields+2) * sizeof(char) * 32);
+ col_names = malloc((num_fields+2) * sizeof(char) * MAXFIELDNAMELEN);
strcpy(col_names, "(" );
@@ -1542,30 +1558,27 @@
precisions[j] = field_precision;
+#ifdef USE_ICONV
+ if ( encoding )
+ utf8str = utf8(encoding, name);
+ if ( ! utf8str ) exit(1);
+ strcpy(name, utf8str);
+ free(utf8str);
+#endif
* Make field names lowercase unless asked to
* keep identifiers case.
- if ( ! quoteidentifiers ) {
- for(z=0; z<strlen(name) ;z++)
- name[z] = tolower(name[z]);
+ if ( ! quoteidentifiers ) LowerCase(name);
* Escape names starting with the
- * escape char (_)
+ * escape char (_), those named 'gid'
+ * or after pgsql reserved attribute names
- if( name[0]=='_' )
- strcpy(name2+2, name);
- name2[0] = '_';
- name2[1] = '_';
- strcpy(name, name2);
- * Escape attributes named 'gid'
- * and pgsql reserved attribute names
- else if(
+ if( name[0]=='_' ||
! strcmp(name,"gid") ||
! strcmp(name, "tableoid") ||
@@ -1575,6 +1588,6 @@
! strcmp(name, "primary") ||
! strcmp(name, "oid") ||
- ! strcmp(name, "ctid")
+ ! strcmp(name, "ctid") )
name2[0] = '_';
@@ -1587,16 +1600,20 @@
if(strcmp(field_names[z],name)==0){
strcat(name,"__");
- sprintf(name,"%s%i",name,j);
+ sprintf(name+strlen(name),"%i",j);
break;
- field_names[j] = malloc ( strlen(name)+3 );
+ field_names[j] = malloc (strlen(name)+1);
strcpy(field_names[j], name);
- sprintf(col_names, "%s\"%s\",", col_names, name);
- sprintf(col_names, "%s\"%s\")", col_names, geom);
+ /*sprintf(col_names, "%s\"%s\",", col_names, name);*/
+ strcat(col_names, "\"");
+ strcat(col_names, name);
+ strcat(col_names, "\",");
+ /*sprintf(col_names, "%s\"%s\")", col_names, geom);*/
+ strcat(col_names, geom);
+ strcat(col_names, ")");
@@ -1647,4 +1664,20 @@
* $Log: shp2pgsql.c,v $
+ * Revision 1.96 2005/08/29 22:36:25 strk
+ * Removed premature object destruction in InsertLineString{WKT,} causing segfault
+ * Revision 1.95 2005/08/29 11:48:33 strk
+ * Fixed sprintf() calls to avoid overlapping memory,
+ * reworked not-null objects existance check to reduce startup costs.
+ * Revision 1.94 2005/07/27 02:47:14 strk
+ * Support for multibyte field names in loader
+ * Revision 1.93 2005/07/27 02:35:50 strk
+ * Minor cleanups in loader
+ * Revision 1.92 2005/07/27 02:07:01 strk
+ * Fixed handling of POINT types as WKT (-w) in loader
* Revision 1.91 2005/07/04 09:47:03 strk
* Added conservative iconv detection code
