[postgis-users] importing shape files nightmare!
Gérald Fenoy
djayweb at djayux.net
Thu Sep 15 05:14:46 PDT 2005
sorry for redundency but ... you could find the
postgis-1.0.4_p20050914.ebuild here : http://www.postgis.fr/gentoo/
dev-db/postgis/postgis-1.0.4._p20050914.ebuild .
Feel free to send any comments here.
Cordially.
Le 15 sept. 05 à 09:12, christomec a écrit :
> Thank you,
> I currently have postgis-1.0.1_p20050727-r1 emerged on my gentoo
> box, why
> does the select postgis_full_version() return POSTGIS="1.1.0CVS"?
> And where can I find a postgis-1.0.4 ebuild?
>> Version 1.0.4 of PostGIS contains a fix for your case.
>> --strk;
>> On Wed, Sep 14, 2005 at 11:38:54PM +0200, christomec wrote:
>>> I have two machines, suse and gentoo
>>> suse:
>>> select version();
>>> PostgreSQL 8.0.3 on i686-pc-linux-gnu, compiled by GCC gcc (GCC)
>>> 3.3.5
>>> 20050117 (prerelease) (SUSE Linux)
>>> select postgis_full_version();
>>> POSTGIS="1.0.3" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS
>>> DBPROC="0.3.0"
>>> RELPROC="0.3.0"
>>> gentoo:
>>> select version();
>>> i686-pc-linux-gnu-gcc (GCC) 3.3.6 (Gentoo 3.3.6, ssp-3.3.6-1.0,
>>> pie-8.7.8)
>>> POSTGIS="1.1.0CVS" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004"
>>> USE_STATS
>>> DBPROC="0.3.1" RELPROC="0.3.1"
>>> running:
>>> shp2pgsql -c streets.shp streets | psql -d dbname
>>> suse, no problem!
>>> gentoo: ERROR: unterminated quoted string at or near
>>> "'010500000001000000010...
>>> trying:
>>> shp2pgsql -D streets.shp streets dbname > streets.sql
>>> suse, no problem!
>>> gentoo:
>>> Shapefile type: Arc
>>> Postgis type: MULTILINESTRING[2]
>>> Segmentation fault
>>> finally:
>>> Trying to import streets.sql generated on the suse machine into
>>> postgresql
>>> running on the gentoo machine also fails:
>>> psql:streets.sql:1350: invalid command \N
>>> What is it with the gentoo installation? What should I upgrade or
>>> downgrade to remedy this problems I'm having?
>>> Please help, it is really important that I get this done and I'm
>>> really
>>> stuck trying to solve it.
>>> Kind Regards,
>>> Christo Du Preez
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> !DSPAM:4329119c36131738919822!
