[postgis-users] importing shape files nightmare!
christomec
christo at mecola.com
Thu Sep 15 05:47:19 PDT 2005
Not successful trying to ebuid postgis-1.0.4_p20050914.ebuild digest
Response:
>>> Downloading
http://distfiles.gentoo.org/distfiles/postgis-cvs-1.0.4_p20050914.tar.gz
--14:40:32--
=> `/usr/portage/distfiles/postgis-cvs-1.0.4_p20050914.tar.gz'
Resolving distfiles.gentoo.org... 156.56.247.195, 216.165.129.135,
64.50.236.52
Connecting to distfiles.gentoo.org[156.56.247.195]:80... connected.
HTTP request sent, awaiting response... 404 Not Found
14:41:06 ERROR 404: Not Found.
No digest file available and download failed.
>>> Downloading
http://distro.ibiblio.org/pub/Linux/distributions/gentoo/distfiles/postgis-cvs-1.0.4_p20050914.tar.gz
--14:41:06--
Resolving distro.ibiblio.org... 152.2.210.109
Connecting to distro.ibiblio.org[152.2.210.109]:80... connected.
14:41:41 ERROR 404: Not Found.
>>> Downloading
http://www.01map.net/gentoo/distfiles/postgis-cvs-1.0.4_p20050914.tar.gz
--14:41:41--
Resolving www.01map.net... 2001:770:139:0:211:2fff:feba:3a94
Connecting to www.01map.net[2001:770:139:0:211:2fff:feba:3a94]:80...
failed: Network is unreachable.
Retrying.
--14:42:16--
(try: 2) => `/usr/portage/distfiles/postgis-cvs-1.0.4_p20050914.tar.gz'
Retrying.
--14:42:18--
(try: 3) => `/usr/portage/distfiles/postgis-cvs-1.0.4_p20050914.tar.gz'
Retrying.
--14:42:21--
(try: 4) => `/usr/portage/distfiles/postgis-cvs-1.0.4_p20050914.tar.gz'
Retrying.
--14:42:25--
(try: 5) => `/usr/portage/distfiles/postgis-cvs-1.0.4_p20050914.tar.gz'
Giving up.
!!! Couldn't download postgis-cvs-1.0.4_p20050914.tar.gz. Aborting.
> The correct link is
> http://www.postgis.fr/gentoo/dev-db/postgis/postgis-1.0.4_p20050914.ebuild
> without space between postgis and postgis-1.0.4_p20050914.ebuild
> Gérald Fenoy wrote:
>> HI Christo,
>> argh realy sorry there is one dot before underscore in the link.
>> The link is then http://www.postgis.fr/gentoo/dev-db/postgis/
>> postgis-1.0.4_p20050914.ebuild (you could also use the http://www.
>> 01map.net/gentoo/dev-db/postgis).
>> A new will be posted in my blog today (http://www.postgis.fr/?q=blog/1).
>> Le 15 sept. 05 à 14:23, christomec a écrit :
>>> Hi GXrald,
>>> Trying to download
>>>> postgis-1.0.4._p20050914.ebuild
>>> I get : "Page non trouvée"
>>> Trying to browse www.postgis.fr/gentoo/dev-db/postgis/ I get: "You
>>> don't
>>> have permission to access /gentoo/dev-db/postgis/ on this server."
>>> Thank you,
>>> Christo
>>>> Hi,
>>>> sorry for redundency but ... you could find the
>>>> postgis-1.0.4_p20050914.ebuild here : http://www.postgis.fr/gentoo/
>>>> dev-db/postgis/postgis-1.0.4._p20050914.ebuild .
>>>> Feel free to send any comments here.
>>>> Cordially.
>>>> Le 15 sept. 05 à 09:12, christomec a écrit :
>>>>> Thank you,
>>>>> I currently have postgis-1.0.1_p20050727-r1 emerged on my gentoo
>>>>> box, why
>>>>> does the select postgis_full_version() return POSTGIS="1.1.0CVS"?
>>>>> And where can I find a postgis-1.0.4 ebuild?
>>>>>> Version 1.0.4 of PostGIS contains a fix for your case.
>>>>>> --strk;
>>>>>> On Wed, Sep 14, 2005 at 11:38:54PM +0200, christomec wrote:
>>>>>>> I have two machines, suse and gentoo
>>>>>>> suse:
>>>>>>> select version();
>>>>>>> PostgreSQL 8.0.3 on i686-pc-linux-gnu, compiled by GCC gcc (GCC)
>>>>>>> 3.3.5
>>>>>>> 20050117 (prerelease) (SUSE Linux)
>>>>>>> select postgis_full_version();
>>>>>>> POSTGIS="1.0.3" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS
>>>>>>> DBPROC="0.3.0"
>>>>>>> RELPROC="0.3.0"
>>>>>>> gentoo:
>>>>>>> select version();
>>>>>>> i686-pc-linux-gnu-gcc (GCC) 3.3.6 (Gentoo 3.3.6, ssp-3.3.6-1.0,
>>>>>>> pie-8.7.8)
>>>>>>> POSTGIS="1.1.0CVS" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004"
>>>>>>> USE_STATS
>>>>>>> DBPROC="0.3.1" RELPROC="0.3.1"
>>>>>>> running:
>>>>>>> shp2pgsql -c streets.shp streets | psql -d dbname
>>>>>>> suse, no problem!
>>>>>>> gentoo: ERROR: unterminated quoted string at or near
>>>>>>> "'010500000001000000010...
>>>>>>> trying:
>>>>>>> shp2pgsql -D streets.shp streets dbname > streets.sql
>>>>>>> suse, no problem!
>>>>>>> gentoo:
>>>>>>> Shapefile type: Arc
>>>>>>> Postgis type: MULTILINESTRING[2]
>>>>>>> Segmentation fault
>>>>>>> finally:
>>>>>>> Trying to import streets.sql generated on the suse machine into
>>>>>>> postgresql
>>>>>>> running on the gentoo machine also fails:
>>>>>>> psql:streets.sql:1350: invalid command \N
>>>>>>> What is it with the gentoo installation? What should I upgrade or
>>>>>>> downgrade to remedy this problems I'm having?
>>>>>>> Please help, it is really important that I get this done and I'm
>>>>>>> really
>>>>>>> stuck trying to solve it.
>>>>>>> Kind Regards,
>>>>>>> Christo Du Preez
>>>>>>> _______________________________________________
>>>>>>> postgis-users mailing list
>>>>>>> postgis-users at postgis.refractions.net
>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> ___________________________________________________________________________
> Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
> Téléchargez cette version sur http://fr.messenger.yahoo.com
> !DSPAM:43296b1c230566092275990!
