[postgis-users] Using X(geometry) and equivalents
strk at refractions.net strk at refractions.net
Thu Sep 15 07:55:40 PDT 2005
Guido, thanks for the report. I've fixed the manual page.
To extract first point of a POLYGON you can use:
	SELECT PointN(ExteriorRing(polygon), 1)
--strk;
On Thu, Sep 15, 2005 at 04:38:29PM +0200, Guido Lemoine wrote:
> Dear All,
> Just another one of these small clarification questions.
> The postgis manual says:
> X(geometry) Find and return the X coordinate of the first point in the
> geometry. Return NULL if there is no point in the geometry.
> (and similar for the Y, Z equivalants)
> I understood this to work on any geometry (e.g. LINESTRING, POLYGON),
> but this is not true. It only works on POINT geometry.
> The first sentence is somewhat misleading therefore. And the last should
> probably say "Return NULL if geometry is not a POINT".
> I was trying to get the X coordinate of the first point of a POLYGON.
> This is not as easy as for a LINESTRING
> (using x(pointN(linestring, 1)). In fact, I'd be interesting to know how
> to do that. Is there a reverse version of
> MakePolygon?
> Keep up the good work,
> Guido Lemoine
> postgis-users mailing list
