[postgis-users] importing shape files nightmare!
christomec
christo at mecola.com
Thu Sep 15 08:04:15 PDT 2005
Unfotunetaly the data belong to a client and is also regarded as sensitive
data.
What I can't understand is the that it works on the suse installation
(source) and not on the gentoo (emerge).
suse:
select version();
PostgreSQL 8.0.3 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.3.5
20050117 (prerelease) (SUSE Linux)
select postgis_full_version();
POSTGIS="1.0.3" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS DBPROC="0.3.0"
RELPROC="0.3.0"
gentoo: [new install: postgis-1.0.4_p20050914.ebuild]
select version();
i686-pc-linux-gnu-gcc (GCC) 3.3.6 (Gentoo 3.3.6, ssp-3.3.6-1.0, pie-8.7.8)
POSTGIS="1.1.0CVS" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0.3.1" RELPROC="0.3.1"
gentoo: [previous install: postgis-1.0.1_p20050727-r1.ebuild]
select version();
> Hi strk,
> do you mean there is still a problem with the
> postgis-1.0.4_p20050914.tar.gz tarball ?
> Christo, please could you send here the problematic shapefile
> please ? We could test it with 1.1.0CVS and the official 1.0.4 one.
> Le 15 sept. 05 à 16:34, strk at refractions.net a écrit :
>> On Thu, Sep 15, 2005 at 04:27:59PM +0200, christomec wrote:
>>> I'm sorry, my mistake. I thought I had the use flags set in a file
>>> somewhere, but that was not the case. I'll try emerging again.
>>> Could this
>>> be why I'm still experiencing the same problems?
>> GEOS and PROJ4 have nothing to do with loading shapefiles.
>> Why don't you get the sources instead of fighting with package
>> managers ? Belive me, that's where the meat is.
>> --strk;
>>>> Well ....
>>>> I've just downloaded the lastest 1.0.4 version of postgis from
>>>> postgis.org and I see that the shp2pgsql.c as the same date
>>>> (2005/08/29 22:36:14) so the problem couldn't came from here I
>>>> think.
>>>> Concerning the geos and proj support you must set proj and geos in
>>>> your USE flags, for more support information use emerge -pv postgis,
>>>> here you've see all the support (red are supports enabled and blue
>>>> are those disabled). To simplify you must reemerge postgis with the
>>>> specified flags, for example you could simply use this command
>>>> line :
>>>> USE="proj geos" emerge -v postgis
>>>> (or -pv to ensure that you'll effectively use geos and proj
>>>> support).
>>>> Hope that help.
>>>> Le 15 sept. 05 à 15:37, christomec a écrit :
>>>>> I have now emerged postgis-1.0.4_p20050914.ebuild, but it seems
>>>>> that the
>>>>> original problems weren't solved. Trying to import a shape file
>>>>> still
>>>>> fails.
>>>>> trying:
>>>>> shp2pgsql -c /tmp/streets.shp streets | psql -d dbname
>>>>> ERROR: unterminated quoted string at or near
>>>>> "'010500000001000000010200000005000000D670917BBAA6394034BDC458A6E94
>>>>> 0C0
>>>>> 2C9ACE4E06A73940A911FA997AE940C0BEF561BD51A7394"
>>>>> at character 292
>>>>> LINE 1: ...TRAND','0687-0890-000','0687-0890-000_6TH
>>>>> AVENUE','010500000...
>>>>> and trying:
>>>>> shp2pgsql -D /tmp/streets.shp streets dbname > /tmp/streets.sql
>>>>> Shapefile type: Arc
>>>>> Postgis type: MULTILINESTRING[2]
>>>>> Segmentation fault
>>>>> shp2pgsql
>>>>> RCSID: $Id: shp2pgsql.c,v 1.96 2005/08/29 22:36:25 strk Exp $
>>>>> POSTGIS="1.1.0CVS" USE_STATS DBPROC="0.3.1" RELPROC="0.3.1"
>>>>> Where is geos and proj4?
>>>>> cat /etc/portage/package.keywords
>>>>> dev-db/postgis ~x86
>>>>> sci-libs/proj ~x86
>>>>> sci-libs/geos ~x86
>>>>>> Attached is a patch to bring shp2pgsql.c from Revision 1.91
>>>>>> to Revision 1.96 (the one shipped with PostGIS 1.0.4).
>>>>>> If you don't have the sources that's ... well ... sad :(
>>>>>> You can still download latest release sources (1.0.4),
>>>>>> run make in the loader/ directory and replace your dumper/loader
>>>>>> with the newly created ones.
>>>>>> .. you can read by the end of the patch all changes
>>>>>> in shp2pgsql since 1.91 ...
>>>>>> --strk;
>>>>>> On Thu, Sep 15, 2005 at 12:28:25PM +0200, christomec wrote:
>>>>>>> I get:
>>>>>>> RCSID: $Id: shp2pgsql.c,v 1.91 2005/07/04 09:47:03 strk Exp $
>>>>>>> Is there a way of just fixing the shp2pgsql without having to
>>>>>>> re-emerging
>>>>>>> postgis?
>>>>>>>> On Thu, Sep 15, 2005 at 11:58:29AM +0200, strk at refractions.net
>>>>>>>> wrote:
>>>>>>>>> On Thu, Sep 15, 2005 at 11:52:08AM +0200, christomec wrote:
>>>>>>>>>> So is POSTGIS="1.1.0CVS" is in actual fact 1.0.3?
>>>>>>>>> Might be, the 1.1 and 1.0 are two different branches in CVS,
>>>>>>>>> and 1.1.0CVS is there since about 1.0.0 is out... there's no
>>>>>>>>> easy way to tell which version of the code 1.1.0CVS is.
>>>>>>>>> Since this is a bug with pgsql2shp what you should look at
>>>>>>>>> is RCSID from it. It is shown running pgsql2shp w/out
>>>>>>>>> arguments.
>>>>>>>> Oops.. sorry, it's shp2pgsql (the loader), NOT pgsql2shp (the
>>>>>>>> dumper).
>>>>>>>> The RCSID is still shown when called w/out args
>>>>>>>> --strk;
>>>>>>>> _______________________________________________
>>>>>>>> postgis-users mailing list
>>>>>>>> postgis-users at postgis.refractions.net
>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> !DSPAM:43297c7440031236047141!
> !DSPAM:43298a29104494037015152!
