[postgis-users] PostGIS and Mapserver
Ezequias Rodrigues da Rocha
ezequias at recife.pe.gov.br
Fri Sep 16 10:55:40 PDT 2005
# psql -d dbpotgis -U postgres -h myserver.mydomain
no problem here
Ezequias
Ethan Alpert wrote:
>Try to connect to the postgres server manually with psql:
>psql -U postgres -h myserver.mydomain
>If you can't connect then the host you are connecting from is not
>allowed. Look at the file $PG_HOME/pg_hba.conf and make sure
>$PG_HOME/postgresql.conf has networking set up.
>-----Original Message-----
>From: postgis-users-bounces at postgis.refractions.net
>[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>Sent: Friday, September 16, 2005 11:04 AM
>To: PostGIS Users Discussion
>Subject: [postgis-users] PostGIS and Mapserver
>Hi list,
>I am trying to access postgis via mapserver (a cgi server) but the
>resoult is allways a problem. Could anobody take a look on my problem ?
>the stack trace is shown below:
>msDrawMap(): Image handling error. Failed to draw layer named 'bairros'.
>msPOSTGISLayerOpen(): Query error. couldnt make connection to DB with
>connect string 'user=postgres password=pt dbname=db1
>host=myserver.mydomain port=5432'.
>Error reported was 'could not create socket: Permission denied '. This
>error occured when trying to make a connection to the specified
>postgresql server.
>Most commonly this is caused by
>(1) incorrect connection string
>(2) you didnt specify a 'user=...' in your connection string
>(3) the postmaster (postgresql server) isnt running
>(4) you are not allowing TCP/IP connection to the postmaster
>(5) your postmaster is not running on the correct port - if its not on
>5432 you must specify a 'port=...'
>(6) the security on your system does not allow the webserver (usually
>user 'nobody') to make socket connections to the postmaster
>(7) you forgot to specify a 'host=...' if the postmaster is on a
>different machine
>(8) you made a typo
>My best regards
>Ezequias
>_______________________________________________
>postgis-users mailing list postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
