[postgis-users] PostGIS and Mapserver
Ezequias Rodrigues da Rocha
ezequias at recife.pe.gov.br
Fri Sep 16 11:38:34 PDT 2005
from ssh terminal.
Locally the problem does not occours too.
see my steps
ssh root at server
password
psql db1
the psql prompt appears.
Ezequias
david techer wrote:
> Hum!
> do you use and type the command
> psql -d dbpostgis -U ....
> to the ssh connection (terminal) or from your local machine?
> if U want to find pg_ctl path do
> which pg_ctl
> or
> pg_config --bindir
> Ezequias Rodrigues da Rocha wrote:
>> but I can enter on the db via ssh connection.
>> This have any difference from entering via apache ?
>> Ezequias
>> Randy James wrote:
>>> looks like the error for the fix listed as number 4
>>> --- Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br> wrote:
>>>> Hi list,
>>>> I am trying to access postgis via mapserver (a cgi server) but the
>>>> resoult is allways a problem. Could anobody take a look on my
>>>> problem ?
>>>> the stack trace is shown below:
>>>> msDrawMap(): Image handling error. Failed to draw layer named
>>>> 'bairros'.
>>>> msPOSTGISLayerOpen(): Query error. couldnt make connection to DB
>>>> with connect string 'user=postgres password=pt dbname=db1
>>>> host=myserver.mydomain port=5432'.
>>>> Error reported was 'could not create socket: Permission denied '.
>>>> This error occured when trying to make a connection to the
>>>> specified postgresql server.
>>>> Most commonly this is caused by
>>>> (1) incorrect connection string
>>>> (2) you didnt specify a 'user=...' in your connection string
>>>> (3) the postmaster (postgresql server) isnt running
>>>> (4) you are not allowing TCP/IP connection to the postmaster
>>>> (5) your postmaster is not running on the correct port - if its not
>>>> on 5432 you must specify a 'port=...'
>>>> (6) the security on your system does not allow the webserver
>>>> (usually user 'nobody') to make socket connections to the postmaster
>>>> (7) you forgot to specify a 'host=...' if the postmaster is on a
>>>> different machine
>>>> (8) you made a typo
>>>> My best regards
>>>> Ezequias
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> __________________________________ Yahoo! Mail - PC Magazine
>>> Editors' Choice 2005 http://mail.yahoo.com
> ___________________________________________________________________________
> Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo!
> Messenger Téléchargez cette version sur http://fr.messenger.yahoo.com
