[postgis-users] loading shapefile in pgAdmin
Nicolas Ribot nicky666 at gmail.com
Mon Sep 19 12:59:08 PDT 2005
> Hi,
> a beginners question...
> is there a possibility to load a shapefile using pdAdmin?
> I tried using the SQL queries window without any success:)
> and could not understand the help file 4.3.2
> thanks
> Sephi
Hi Sephi,
If you generated a valid SQL script with the shp2pgsql loader, it is
possible to run this script with pgAdmin SQL window.
Nicolas
