[postgis-users] Mapserver extent question
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Sep 20 14:23:13 PDT 2005
Hello David,
David Niergarth wrote:
> Hello,
> I have an extent from mapserver (e.g., "-121.682485 38.408966
> -121.231440 38.763359") that I want to feed back into a PostGIS query.
these values are (xmin ymin xmax ymax)
> How do I express this extent in my query?
> I want to write a query something like
for this && selects all the_geom that has a bbox the overlaps with <what
goes here> so you can create a line from xmin,ymin to xmax,ymax and it
will have the bbox you want for the comparison
MakeLine(MakePoint(xmin, ymin), MakePoint(xmax, ymax))
> select recid from tbl_points
> where the_geom && <what goes here?> ;
> A related question... What's a BOX (see following query):
This is the bbox of the extents of all the the_geom objects returned by
your query. you can access the fields of the BOX() maybe? with
xmin(), ymin(), xmax(), and ymax() functions
-Steve Woodbridge
> select extent(the_geom) from tbl_points ;
> extent
> BOX(-124.278755187988 32.5427703857422,-73.5306396484375 46.1519355773926)
> (1 row)
> It doesn't appear to be a WKT format. Is there a way to use BOX like you
> would with other WKT formats?
> Thanks for any suggestions.
> --David
> postgis-users mailing list
