[postgis-users] distance and intersection with 3d geometries
strk at refractions.net
Tue Sep 27 08:22:51 PDT 2005
The result you show is expected and intended.
In an overlay operation any Z value of input nodes
is taken into consideration for the output Z.
If the 0 in your second point is intended as a padding
value substitute it with a 2d point and the resulting Z
will be 1.
--strk;
On Tue, Sep 27, 2005 at 02:15:43PM +0200, Steffen Macke wrote:
> > Since GEOS-2.1.1 intersection() somehow supports 3d.
> Below you find a small example that illustrates the problem.
> Is this behaviour going to change in the near future? Being able to
> do three-dimensional intersection of points (or even better lines) would
> be a very useful feature.
> hna=# select asewkt(intersection('POINT(1 1 1)', 'POINT(1 1 0)'));
> asewkt
> POINT(1 1 0.5)
> (1 row)
> hna=# select postgis_full_version();
> POSTGIS="1.0.4" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS DBPROC="0
> .3.0" RELPROC="0.3.0"
> postgis-users mailing list
