[postgis-users] shp2pgsql segfault and gdb
Amos Hayes
ahayes at polkaroo.net
Thu Sep 29 16:12:07 PDT 2005
strk wrote:
> Jorg Heymans wrote:
> > strk at refractions.net wrote:
> > > What architecture are you running the loader from ?
> > I tested on 2 hardware configs, both fail.
> > - dual P3 , 750MB ram running slackeware 10
> > - dual opteron 246, 4GB ram running gentoo (64bit). Note that on
> this
> > architecture I get a slightly more descriptive errormessage
> before the
> > segmentation fault :
> > Shapefile type: Arc
> > Postgis type: MULTILINESTRING[2]
> > MULTILINESTRING 3065 as 1 vertices, set to NULL
> > *** glibc detected *** double free or corruption (!prev):
> > 0x000000000050d800 ***
> > Aborted
> Ok, I think I fixed the problem, could you test latest
> revision from the pgis_1_0 branch of postgis CVS ?
> This probably calls for release 1.0.5 ...
> --strk;
Just thought I'd let you know that when I run shp2pgsql on a shape
file containing "LATIN1" characters but don't specify "-W LATIN1" as
a parameter to shp2pgsql, I see a similar type of error:
*** glibc detected *** double free or corruption (out):
0x0000007fbffff390 ***
Stumped me for a while there.
Amos
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050929/856fd250/attachment.html>
