[postgis-users] isvalid(the_geom) crash my db
strk at refractions.net
Fri Sep 30 02:05:44 PDT 2005
On Thu, Sep 29, 2005 at 08:16:39PM -0300, Marco Vieira wrote:
> Hi all.
> My db crash when I do select *,isvalid(the_geom) from foo limit 1;
> foo is created by shp2pgsql with only -s 4291 option (second time I
> tried -w option with same result).
> foo have:
> gid serial NOT NULL,
> the_geom geometry,
> CONSTRAINT ba_se_pkey PRIMARY KEY (gid),
> CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
> 'MULTIPOLYGON'::text OR the_geom IS NULL),
> CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 4291)
> WITH OIDS;
> The message log is:
> "server closed the connection unexpectedly
> This probably means the server terminated abnormally before or while
> processing the request."
> My postgis_full_version() is: POSTGIS="1.0.0" GEOS="2.1.4" PROJ="Rel.
> 4.4.9, 29 Oct 2004" USE_STATS DBPROC="0.3.0" RELPROC="0.3.0"
> On debian kernel 2.6.8-2-386.
> Other queries such as select *,area(the_geo) from foo can be done.
> Any clue?
Could you provide the_geom value ?
SELECT the_geom from foo limit 1;
So we can test against new (and same) version...
--strk;
