[postgis-users] shp2pgsql segfault and gdb
Amos Hayes
ahayes at polkaroo.net
Fri Sep 30 09:42:46 PDT 2005
On 30-Sep-05, at 12:25 PM, strk at refractions.net wrote:
> <doc_snippet>
> The -W defines an encoding of the input data (dbf file).
> When specified all attributes of the dbf are converted to UTF-8.
> The resulting .sql script will contain a command to set CLIENT
> ENCODING
> to UTF-8, so that the backend will be able to reconvert from UTF-8
> to whatever encoding the database has been created with.
> </doc_snippet>
> Most likely you will have a Latin1 backend, so the conversion flow
> would be:
> 1: Latin1 -> UTF8 (shp2pgsql)
> 2: UTF8 -> Latin1 (sql session)
> If you have a UTF8 database:
> 2: NO CONVERSION (sql session)
> -strk;
That clears things up. Thank you very much. Might I suggest the
following modified doc snippet? Also, could you list what character
set arguments are allowed, or link to a list of them?
P.S. I think PotgreSQL now creates databases in "UNICODE" by default.
Am I correct in thinking that UTF-8 is a subset of UNICODE, therefore
no conversion will need to happen on import?
<doc_snippet>
The -W option specifies the encoding of the input data (dbf file).
When used, all attributes of the dbf are converted from the specified
encoding to UTF-8. The resulting SQL output will contain a command to
set CLIENT ENCODING to UTF-8, so that the backend will be able to
reconvert from UTF-8 to whatever encoding the database is configured
to use internally.
</doc_snippet>
Amos
