[postgis-users] Querying MapServer PostGIS layer
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Apr 13 07:53:44 PDT 2006
Dave,
Shapefile attribute columns are all UPPERCASE and Postgres/postgis
attribute columns are all lowercase so you need to make sure that the
reference to the attribute columns in your template match the case
expected by the data source.
-Steve W
Dave Stone wrote:
> Please excuse if this post has been asked before; I'm new to the list
> and finding it difficult to locate all the hidden gems of wisdom!
> I'm having a problem with querying a MapServer layer consisting of
> points stored in a PostGIS table. The plan is simple enough: I'm
> displaying the dots together with a boundary and an annotation layer,
> and I want to click on a dot and have a page come up showing non-spatial
> attributes from the PostGIS record for that location.
> What happens when I click a dot is I get a completely blank page titled
> 'MapServer Message' (but no message). The relevant bit of the MapServer
> .map file is:
> LAYER # query layer using the loccoords PostgreSQL table
> CONNECTIONTYPE postgis
> NAME saint_locations
> CONNECTION "user=erdb13 dbname=stdraft"
> DATA "geom from loccoords using unique locationref using
> srid=27700"
> STATUS ON
> DEBUG ON
> TYPE POINT
> TOLERANCE 25
> CLASS
> NAME "Locations"
> MINSCALE 2000000
> TEMPLATE "result.html"
> DEBUG ON
> STYLE
> SYMBOL "circle"
> SIZE 5
> COLOR 255 0 0
> OUTLINECOLOR 0 0 0
> END
> END
> This whole idea is based on an example in the MapServer tutorial
> (http://hypnos.cbs.umn.edu/tutorial/section3.html, choose Ex.3.1). The
> example works fine, so why doesn't my version? The answer seems to be
> that the layer being queried in the example is a shapefile whereas mine
> is in PostGIS. To test this suspicion, I amended the layer definition
> in the .map file as follows:
> # CONNECTIONTYPE postgis
> # CONNECTION "user=erdb13 dbname=stdraft"
> DATA "/var/www/html/saints/data/parish/locs"
> STATUS ON
> 'locs' is a shapefile produced by dumping (with pgsql2shp) the
> 'loccoords' table in the first DATA statement above.
> With only this trivial change, the query template 'result.html' works as
> intended. But since I want to use the PostGIS functionality, I need to
> find out what's wrong with the first LAYER spec. above.
> Any suggestions most gratefully received,
> Dave
> postgis-users mailing list
