[postgis-users] php query problem "AsText(table.geometry)", multiple schemas
Andreas Neumann neumann at karto.baug.ethz.ch
Thu Apr 13 12:48:57 PDT 2006
I have the very strange situation that a query works fine in the psql
client or in pgadminIII, but the exact same query doesn't work in php5.
Maybe I have to mention that I have three schemas in the db: public
(contains the postgis functions and tables), two other schemas
containing the actual data.
Here is my SQL query:
SELECT place.brief_place AS place, place.place_number, event.event AS
event_type, event_rels.display_date AS display_date,
event_rels.start_date AS start_date, event_rels.end_date AS end_date,
place.tgnid as tgnid, AsText(coordinates.the_geom_albers) AS geom FROM
ulan.place, ulan.event, ulan.event_rels, tgn.coordinates WHERE
event_rels.subject_id = 500019902 AND event.event_id =
event_rels.event_id AND event_rels.place = place.place_number AND
place.tgnid = coordinates.subject_id ORDER BY event_rels.display_date ASC
and here is my php code:
$mySQL = 'SELECT subject.subject_id AS subject_id, subject.level AS
level, subject.scope AS biographylong, term.term AS name,
biography.birth_date AS birth_date, biography.death_date AS death_date,
biography.biography AS biography, biography.sex AS sex,
ptype_role.ptype_role AS preferred_role, biography.birth_place AS
birth_place, biography.death_place AS death_place FROM ulan.subject,
ulan.term, ulan.biography, ulan.ptype_role_rels, ulan.ptype_role WHERE
subject.level <= '.$level.' AND subject.record_type = \'P\' AND
subject.subject_id = term.subject_id AND subject.subject_id =
biography.subject_id AND subject.subject_id = ptype_role_rels.subject_id
AND ptype_role_rels.ptype_role_id = ptype_role.ptype_role_id AND
term.preferred = \'P\' AND biography.preferred = \'P\' AND
ptype_role_rels.preferred = \'P\' AND biography.death_date >=
'.$beginDate.' AND biography.birth_date <= '.$endDate.' ORDER BY
biography.birth_date';
$my_result_set = pg_query($my_pg_connect,$mySQL) or die (pg_ErrorMessage());
and here is the error message that I get:
<br />
<b>Warning</b>:  %v%v() [<a href='function.%v'>function.%v</a>]: Query
failed: ERROR:  function astext(public.geometry) does not exist
HINT:  No function matches the given name and argument types. You may
need to add explicit type casts. in
<b>/home/an/www/phd/prototype/unstable/sendArtistData.php</b> on line
<b>92</b><br />
<br />
<b>Warning</b>:  pg_num_rows(): supplied argument is not a valid
PostgreSQL result resource in
<b>93</b><br />
It seems that it can't find the function AsText(). I made sure it is
present in schema "public". The geometry data is in schema "tgn". Do I
have to tell php something about the multiple schema situation? Some
sort of environment variable?
Thanks for any information!
Andreas
Andreas Neumann
Institute of Cartography
ETH Zurich
Wolfgang-Paulistrasse 15
CH-8093  Zurich, Switzerland
Phone: ++41-44-633 3031, Fax: ++41-44-633 1153
e-mail: neumann at karto.baug.ethz.ch
www: http://www.carto.net/neumann/
SVG.Open: http://www.svgopen.org/
Carto.net: http://www.carto.net/
