[postgis-users] problem to install 1.1.2 on AIX
Paolo De Simone pdesimone at infocall.it
Tue Apr 18 08:26:20 PDT 2006
Hello all,
i'm trying to install PostGIS 1.1.2
over PostgreSQL 8.1.3
on AIX 5.2 RISC 6000
the steps
- gmake
- gmake install
are OK
but when run
psql -f lwpostgis.sql -d myDB
had the following result :
 BEGIN
psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:45: NOTICE:  type
"histogram2d" is not yet defined
DETAIL:  Creating a shell type definition.
psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:45: ERROR:  could
not load library "/usr/local/postgresql8_1_3/pgsql/lib/liblwgeom.so": Cannot
run a file that does not have a valid format.
psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:50: ERROR:
current transaction is aborted, commands ignored until end of transaction
block
psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:58: ERROR:
block
psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:3358: ERROR:
block
ROLLBACK
Many thanks to anybody that can help me.
Greetings
paolo
