[postgis-users] function difference(geometry, geometry) throws an exception
toni hernnadez
thernandez at correo.giscampus.org
Mon Apr 24 02:03:07 PDT 2006
HI,
If I execute the sql that follows I got the error:
NOTICE: TopologyException: side location conflict (498355,651613,651613)
ERROR: GEOS difference() threw an error!
Does anyone know what this means?
I use buffer, intersection and diference functions. All in the same sql
I have tested this in postgis version 1.1 and 1.0.
This is the sql hat throws the exception is this one:
select astext(difference(
(GeomFromText('POLYGON((498356.421005198
651606.895014999,498352.452255198 651623.299181666,498370.708505198
651634.940848333,498405.898088531 651651.080431666,498441.616838531
651665.367931666,498469.662671864 651680.713764999,498473.631421864
651670.130431666,498479.716838531 651644.465848333,498488.183505198
651612.451264999,498468.339755198 651603.190848333,498387.112671864
651566.149181666,498374.412671864 651562.709598333,498372.562028232
651563.436636902,498372.785232024 651564.01338174,498372.987592376
651565.172049121,498372.960019638 651566.347931579,498370.049602971
651590.160431579,498369.952570713 651590.594769057,498369.986735951
651590.441838025,498369.952368124 651590.728125827,498369.858822152
651591.014407994,498369.793156749 651591.308340611,498369.676598025
651591.572075168,498369.587038588 651591.846157196,498361.914121922
651609.308657196,498361.337694991 651610.333933648,498360.572322429
651611.227054386,498359.647417073 651611.953697279,498358.598522519
651612.485937849,498357.465947195 651612.80332239,498356.293215336
651612.893653991,498355.12539437 651612.753461259,498355.01255936
651612.716591129,498356.421005198 651606.895014999))',23031))
(select
intersection(
(select buffer(geomfromtext('LINESTRING(498356.421005198
651606.895014999,498352.452255198 651623.299181666)',23031),6))
