[postgis-users] Re: PostGIS setup - Ubuntu Breezy + PostgreSQL-8.1
Randy Burkhardt
randy.burkhardt at gmail.com
Thu Apr 27 09:56:51 PDT 2006
wow, you are correct
I've got pg_config 5 times
home/randy/postgresql-8.1.3/src/bin/
home/randy/postgresql-8.1.3.src/bin/pg_config/
usr/bin/
usr/lib/postgresql/8.1/bin/
usr/local/pgsql/bin/
I thought I had a pretty clean install, I guess a couple slips is all it
takes to muck it up. I think I only goofed twice and I didn't think it was
that serious, couple steps out of order and then gone back- however I re-ran
postgresql-8.1.3 install last night, I gues that's where some of the problem
is, but yet these original problems still have to be fixed.
Thanks
well it will be interesting to see what I can do here, in the meantime I'm
going to pop in a new harddrive and start over.
Thanks
On 4/27/06, strk at refractions.net <strk at refractions.net> wrote:
> On Thu, Apr 27, 2006 at 09:32:24AM -0700, Randy Burkhardt wrote:
> > pg_config --includedir-server returns
> > /usr/include/postgrsql/8.1/server
> > however I find 'postgres.h' these 3 places
> > usr/local/pgsql/include/server/
> > usr/include/postgresql/
> > home/randy/postgresql-8.1.3/src/include/
> Your installation is pretty screwed up Randy.
> You probably have more then one pg_config, at
> least one for each postgres.h you found.
> If you handle to find it pass it to PostGIS (not GEOS)
> configure script:
> For example:
> ./configure --with-pgsql=/usr/local/pgsql/bin/pg_config
> --strk;
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060427/5e57c2fb/attachment.html>
